20 Most Recent Frigidaire 16.5 Cu. Ft. Top-Mount Refrigerator - White Questions & Answers
In the house we just bought there is a copper
Freezers only buils up layers of ice after multiple opebing and closing of doors allows fresh air inside, the moisture then freezes out of the air and builds up in layers on the cold surfaces. Note that the more ice that builds up decreases the efectivness of the freezr and thus costs more to run. To test try making ice cubes in atray. The number 1 setting on the fridge will be the warmest setting. Hope this helps.
9/29/2017 9:04:18 AM • Frigidaire 16.5... • Answered on Sep 29, 2017
If the refrigerator is not cooling and neither is the freezer, what could it be
start it on the middle setting.. sometimes if you start it off at the colder settings will not cool
12/21/2014 10:08:35 PM • Frigidaire 16.5... • Answered on Dec 21, 2014
New frid 10 hrs old freezer fan running steady is
Yes... nothing to worry about...
heatman101
8/28/2011 2:37:30 AM • Frigidaire 16.5... • Answered on Aug 28, 2011
My freezer is not freezing
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
8/10/2011 4:29:38 PM • Frigidaire 16.5... • Answered on Aug 10, 2011
Water under vegtable bin every
Hi
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan. Your drain tube may be clogged up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Please get back to us if you have further query else please accept the suggestion. Thank you for contacting fixya.com
8/5/2011 9:43:46 AM • Frigidaire 16.5... • Answered on Aug 05, 2011
Fairly new 16.5 Frigidaire top Freezer is cold,
Here is a link to the Frigidaire support site where you can download a manual. Frigidaire Support,. There are two types of manuals, a user manual and a wiring digram. These will give you an Idea as to the location of the fan. Yes, if the fan is not turning the fridge side will get warm. Do not start replacing parts until you have a better idea what is what. Calling in a repair person is up to you, but first check out the Manuals read the troubleshooting facts at the end and then decide.
8/2/2011 1:02:57 AM • Frigidaire 16.5... • Answered on Aug 02, 2011
Frost (ice)forms on back of freezer and the
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
5/8/2011 12:07:32 AM • Frigidaire 16.5... • Answered on May 08, 2011
0answers
Fridge Too Cold
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
12/27/2010 11:59:23 PM • Frigidaire 16.5... • Answered on Dec 27, 2010
Where is the relay of
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101 /
10/8/2010 2:25:06 AM • Frigidaire 16.5... • Answered on Oct 08, 2010
I have top freezer refrigerator
There is a damper between the 2 sections that opens and closes based on the temp of the fridge.
One of the following could be the problem...
** Thermostat defective.
** Damper solenoid defective.
** Damper door frozen shut.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
8/27/2010 1:31:10 PM • Frigidaire 16.5... • Answered on Aug 27, 2010
I have a top-mount Refrigerator Model FRT221NLHWO.
take out the whole back wall cover to access the fan. this is very straight-forward stuff once you see it.
8/15/2010 8:30:04 PM • Frigidaire 16.5... • Answered on Aug 15, 2010
Freezer is defrosting. Compressor turns on, then
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
6/4/2010 5:31:04 AM • Frigidaire 16.5... • Answered on Jun 04, 2010
0answers
Smell
Be the first to answer 4/14/2010 10:22:05 PM • Frigidaire 16.5... • Posted on Apr 14, 2010Be the first to answer
Refrigerator clicks then sounds like a fan runs
your relay on compresor is out. check and see if compresor runs
2/13/2010 10:44:56 PM • Frigidaire 16.5... • Answered on Feb 13, 2010
Refirgerator was connected to regular wall outlet
Yes it is risky and you can fry the compressor because of the voltage drops in the house wiring and extension cord. If it clicked a lot that is most likely what happened.
11/30/2009 5:56:58 AM • Frigidaire 16.5... • Answered on Nov 30, 2009
Frigidaire 16.5 Cu. Ft. Top-Mount Refrigerator - White Logo
28 questions posted
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Refrigerators
Most Popular Question
water under vegtable bin every
  • Refrigerators
