20 Most Recent Juki DDL-8700 Questions & Answers
tip
GUR Enterprise UK LTD - Sewing Machines in England
GUR Enterprise UK LTD is a leading company that offers sewing machines in England. Our online store holds a large range of sewing equipment and accessories to help sewers, seamstresses and sewing enthusiasts in England create outstanding artwork. https://www.sewingmachinesinengland.co.uk/
/uploads/images/img2 (2)-undefined-undefined-0.png
on Nov 21, 2023 • Juki DDL-8700
I have a Juki 8700- 7. How do you lengthen thread of the automatic cutter please?
Check out the videos. It is adjustable
5/31/2023 5:22:23 AM • Juki DDL-8700 • Answered on May 31, 2023
Error Code on Juki DDL 8700 Machine - E1 or E001
If it is only 90 days old it is under manufacturer warranty. Contact them for a free replacement. They don't list an E1 Error https://www.manualslib.com/manual/522984/Juki-Ddl-8700.html?page=40#manual
Product Registration
Juki Home https://www.jukihome.com > warranty If at any time during the applicable limited warranty period, the product is determined to be defective JA will replace or repair the Product, at JA's option. Doesn't include: 8700 ‎' Must include: 8700
  • FAQs
    https://www.jukihome.com > faq For a limited warranty period of two years on motors, light assembly, wiring, switches, circuit boards, and speed control; and for a limited warranty period ...
4/24/2023 6:03:32 PM • Juki DDL-8700 • Answered on Apr 24, 2023
2answers
SC-810 ERROR E071
hi there concern ERROR ( E071 ) means Disconnection o motor output connector. please check the motor output connector for loose connection and disconnection. otherways means IPM module is defective. if you need more help please contact me. BEST REGARDS ASHRAF ABOZID [email protected]
11/26/2022 2:29:53 AM • Juki DDL-8700 • Answered on Nov 26, 2022
Does The Juki 8700 sewing machine have a automatic Thread Triimmer
final answer about this questionhello allin case of normal machine you need to add many parts to convert from manual to auto thread trimmer ( need electronic motor with control - auto thread trimmer mechanic components - hook - feed dog - etc.... ) it's very difficult to change from normal to auto thread trimmer.best regardsashraf abozid
10/29/2022 11:58:29 PM • Juki DDL-8700 • Answered on Oct 29, 2022
Why doesn't pressure foot lower completely?
look behind the end cover as you rotate the belt pulley by hand they all have adjustments there
4/30/2021 2:45:45 PM • Juki DDL-8700 • Answered on Apr 30, 2021
2answers
Error 924
hi there regarding Error E924 at JUKI control it means Motor driver failure ( Motor driver has broken.) or you can first check motor connection if connected secure or there's lose connection. other ways try to change motor with new one or check control box only with working machine to confirm Error coming from motor or control box. BEST REGARDS ASHRAF CAIRO - EGYPT [email protected]
6/3/2020 8:28:30 AM • Juki DDL-8700 • Answered on Jun 03, 2020
Checking the oil level on a juki ddl-8700
Hi there, gently tilt the head of your machine back and rest it on the white peg thing at the back. Inside you should see lines on the back side of the oil pan...min and max. If you are somewhere in between, all good. If not, add more. NOTE: always use clear machine oil. Any other stuff will stain your work. Hope this helps, have a great day
12/7/2019 8:51:57 AM • Juki DDL-8700 • Answered on Dec 07, 2019
Stretch stitch juki 8700
Hi there, no you cannot do a stretch stitch on the ddl-8700. It only has on stitch and it is a straight lockstitch.
12/7/2019 8:45:51 AM • Juki DDL-8700 • Answered on Dec 07, 2019
Some times Error-2 & some
hi there
1- your control box model is SC-500 not SV500, juki didn't made sv never ever
2- there is no error 2 just error 3 and error 4 both means there's problem with synchronizer which installed behaind handwheel first try to clean it by dray spray maby there's some oil or dust arround it. if error still coming change the senchronyzer with new one
best regards
ashraf abozid
[email protected]
6/29/2018 8:37:07 PM • Juki DDL-8700 • Answered on Jun 29, 2018
My machine Juki DDL8700 The Hand wheel is to hard to turn by hand I know it is something to do with the back lever connected to the stich length I am doing some thing wrong
Any chance you broke a needle? 1. First take your feed plate off and then see if the hand wheel turns freely. If it does, look at the plate to see if it is bent. If bent, lay on a flat surface and tap with a hammer until it's flat and put is back on. If it's in bad shape, you will need to buy another one. This should also free up your back lever.
10/2/2017 8:05:11 PM • Juki DDL-8700 • Answered on Oct 02, 2017
10answers
Why my juki ddl-555-5, wheneve I turn on the power switch, just run split second then it automatically turns off?
Try swaping the wires that you cut you might have them backward.if that don't doit you might try changing the hole cord to a new one .
9/28/2017 8:29:50 PM • Juki DDL-8700 • Answered on Sep 28, 2017
I have a Juki ddl
Your table sounds like it was cut for a different machine..You might be able to move your motor over to where the belt will come straight down from the handwheel. There is some adjustment that can be made with a wrench on the large nuts that hold the motor up to the table. Good luck.
9/3/2017 3:00:36 AM • Juki DDL-8700 • Answered on Sep 03, 2017
I have a JUKI DDL-8700N. I recently moved the machine and the movers turned the machine on its side. Now the sewing speed is very fast and it doesn't stop when I take my foot off the pedal.
Carmen, Your belt is either twisted or is not down in the groove in the hand wheel or in the pulley that is on the end of your motor. Use a flashlight to look at the end of your motor (under your table). That is a common problem. Once you think it is probably on both the hand wheel and the pulley, start turning the hand wheel towards you about 10 times. Sometimes that helps it settle in. When this happens, the hinges sometimes get crooked and you will need to try to straighten them by jiggling the head of the sewing machine until it settles in. Good luck.
8/25/2017 2:50:13 AM • Juki DDL-8700 • Answered on Aug 25, 2017
Elna 704 DEX needle bar broke
I looked everywhere on line that I could think of and couldn't find one. I have had luck looking for other parts I needed by watching ebay selling a model for parts. My go to mechanic is in Cleveland OH at the Geo. E. Johnson Co. Ask Herb or Jerry if they can order the part and have it sent to you.800-729-6341.
3/29/2017 12:50:36 AM • Juki DDL-8700 • Answered on Mar 29, 2017
Bobbin house is not lined up with the needle for a full turn. How can I fix this?
Your machine is out of time. This means that your bobbin casing is not rotating at the right time to be able to grab the thread from your needle. You should take it to the mechanic to have it fixed.
2/3/2017 2:52:44 AM • Juki DDL-8700 • Answered on Feb 03, 2017
Manual backtack lever works but electronic servo backtack only engages when machine is at rest with needle in up position.
hello there at normal case needle bar must be in upper position because DDL-8700/7 does not equipped with needle feed. for your problem please check back tack solenoid open and close when you make back tack ( sometimes it was jammed and need to move by hand ). best regards ashraf abozid Cairo - Egypt [email protected]
11/3/2016 9:59:28 PM • Juki DDL-8700 • Answered on Nov 03, 2016
How can I run pressure foot selector switch
Pressure on foot is regulated by the screw on the top of the machine directly above the pressure foot bar. Make sure your lever on back of machine is down, then turn the screw by hand, left for less pressure and to the right for more pressure. Has anyone adjusted the presser foot inside the machine? That can throw it off or sometimes you need to look under the machine head into the oil pan to make sure there isn't something stuck and holding the pressure up from there. Is this a new or used machine? Does it have enough oil in the pan?
11/2/2016 11:43:05 AM • Juki DDL-8700 • Answered on Nov 02, 2016
Juki DDL-8700 Logo
258 questions posted
Top Juki Sewing Machines Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Juki Sewing Machines
Most Popular Question
error code juki ddl 8700 machine e1 or
  • Sewing Machines
