20 Most Recent
Mathsoft StudyWorks! Mathematics Deluxe 5.0 (11513) for PC Questions & Answers
How to make the pupils or students love math
HA well im answering this with experiences of my math teacher Try to tell interesting stories about math (even if your exagerationg a little) with yourself in those stories also if that doesnt work make jokes durring the class not to the point where u offend your students but make them pretty bizzar and your students will buffen up to math. Also try to lower your homework if your giving a lot and gradually work your way up to ur current amount
6/18/2022 11:28:45 AM •
Mathsoft...
Answered
on Jun 18, 2022
Total population 5000,10% increase in men and 15%
use simultaneous equations, with x = # of men and y = # of women:
x + y = 5000 --> convert to x = 5000 - y
1.1x + 1.15y = 5600
1.1 (5000 - y) + 1.15y = 5600
5500 - 1.1y + 1.15y = 5600
.05y = 100
y = 2000
plug y = 2000 into x + y = 5000
therefore x = 3000
3/13/2016 5:16:06 PM •
Mathsoft...
Answered
on Mar 13, 2016
What constitutes a rational expression?
The ratio of two polynomial expressions. But before getting this, you need to know what constitutes a polynomial (expression).
In a polynomial is some indeterminate x, you can only have positive integer powers of x, such as x^0=1, x, x^2, x^n (n restricted to be a positive integer).
9/14/2015 11:30:32 AM •
Mathsoft...
Answered
on Sep 14, 2015
110011 TO BASE 10
Assuming the original number is base 2, the place values are:
5 4 3 2 1 0 (these are intended to be superscripts)
2 2 2 2 2 2 or:
32 16 8 4 2 1
in the question, the number was 110011 which is,
1 * 32 = 32
1 * 16 = 16
0 * 8 = 0
0 * 4 = 0
1 * 2 = 2
1 * 1 = 1
sum is 51 (base 10)
6/29/2015 5:23:24 PM •
Mathsoft...
Answered
on Jun 29, 2015
25 is 62.5% of 40 what are the step by step
There are no unknowns in this question, but the step by step process for interpreting the words are:
1)' 25 is' means 25 =
2)' 62.5%' means 62.5/100, so 25 = 62.5/100
3)' of' means denominator of subject (which is the 25), so:
25/40 = 62.5/100.
This might be easier to see if there were an unknown. For example: 25 is what percent of 40? Using the above interpretation, this becomes:
25/40 = x/100 then solve for x.
Or, another example: 25 is 62.5% of what?
25/x = 62.5/100
6/29/2015 5:15:22 PM •
Mathsoft...
Answered
on Jun 29, 2015
What's the answer to 15 17/100 - 2 3/4
To add or subtract fractions, the denominators must be the same. The lowest common denominator in the question is 100, so 3/4 becomes 75/100:
15 17/100 14 117/100
-2 75/100 is the same as -2 75/100
12 42/100 = 12 21/50
6/29/2015 4:54:32 PM •
Mathsoft...
Answered
on Jun 29, 2015
How do i round 14,389 to the nearest thousand?
From a programming point of view, add half the 'to the nearest' number (in this case - to the nearest thousand - means add 500) and truncate (zero out) anything less than the 'to the nearest' number. So:
14,389 + 500 = 14,889 => 14,000
6/29/2015 4:47:01 PM •
Mathsoft...
Answered
on Jun 29, 2015
How do i improve in math
Math and math, not easy for most of us. What you can do is take the method/work you did in the second quarter and find out where in the learning prosess things got difficult. When you have done that, then you know what you are able to do and what not.
Start a bit before where you stopped and work your way through the methods you did not master.. If you have an access to a math teacher he could help you categorise the methods. It is best to start where you do the work without a problem and progress to the more complicated things.
good luck
kolbrun
4/5/2015 10:16:57 AM •
Mathsoft...
Answered
on Apr 05, 2015
Convert 0.15072464 to percent
1.0 = 100%
0.1 = 10%
0.01 = 1%
Therefore 0.15 = 10% + 5% --> 15% The rest of the number is irrelevant in this case.
3/29/2015 12:03:42 PM •
Mathsoft...
Answered
on Mar 29, 2015
