20 Most Recent Reddy Heater-30-55,000 BTU Variable Questions & Answers
4answers
Reddy Heater keeps shutting down
check your cad cell. replace this. it is not detecting a flame. replacing the cad cell will fix your problem. when it shuts down it goes into lockout.
1/7/2020 6:56:27 PM • Reddy... • Answered on Jan 07, 2020
Heater turns on for a few seconds then goes out
Absolutely K1 or diesel can get old in a hurry, the ultra-low Sulphur diesel has been tinkered with so much that it turns to book varnish much faster than before 2010. Most of those heaters spray fuel past the igniters using a siphon much like a spray paint gun, the suction tube may have dry rot or a small air leak and it it takes but a tiny air leak to kill the siphon effect. Check the tube from the nozzle all the way down to the fuel tank or replace it if you're not certain it is not compromised or dry rotted.
10/12/2017 12:35:11 PM • Reddy... • Answered on Oct 12, 2017
2answers
Vogelzang kerosene heater will not ignite (no spark)
There is an igniter module and then the igniter electrodes (check the air gap) that produces the spark to start the fuel burning, both could be defective.
5/19/2017 3:00:52 PM • Reddy... • Answered on May 19, 2017
Ready heater will run then shuts off
Change out the thermocouple.
3/18/2016 6:28:12 PM • Reddy... • Answered on Mar 18, 2016
Reddy heater r35
no it doesn't - the ignitor goes to printed circuit connectors on your control board. the ignitor operates on 120 volts ac. for repair parts on any reddy heater go to www dot desatech dot com
5/12/2015 4:59:05 PM • Reddy... • Answered on May 12, 2015
3answers
My 3500 btu reddyheater propane runs great but stinks up my shop never noticed before gives me a headacKe
With any unvented gas heater, you still need fresh air coming in to breath. Long exposure in a closed room with these type heaters will cause headaches, nausea, light headedness, etc. If you think something may be wrong with the heater, check the inside of the heater where the flames are. Is it sooted? If it is, it is not burning correctly and may need the pressure adjusted or cleaned. Is the cylinder you are using freezing up on the outside of the bottle? You may just need to switch to a full cylinder. Hope this helps.
3/29/2015 10:33:24 PM • Reddy... • Answered on Mar 29, 2015
I have a 35,000 btu Reddy heater that won't fire at the spark plug but is getting a signal from the magneto. Is the magneto bad or does the spark plug have to be in the mist of kerosene to spark?
  1. The FIRST STEP in diagnosing any heater problem should be checking the output of the air pump. Determine the air pressure required for the heater model that is being tuned. The air pump, in turn, is responsible for fuel delivery.
  2. If you do not know the required pressure look for a decal on the side (usually) of your heater. This decal will state the model number, serial number, fuel capacity, pump pressure, etc.
  3. If your plastic end cover looks like this......
m29609t.jpgM29609 has 2 threaded holes. The hole on the left has a square plug inserted. Remove the plug. Screw in the nipple end of the gauge into the threaded hole. Check for air leaks with soapy water. or If your plastic end cover looks like this...... m16545t.jpgM16545 has 2 threaded holes. The shorter projection with a hole on the left has a square plug inserted. Remove the plug. Screw in the nipple end of the gauge into the threaded hole. Check for air leaks with soapy water. 4. The other hole (longer projection) has a screw with a hole which adjusts a ball and spring relief valve assembly. Carefully adjust the screw until the gauge is reading the pressure level that is specified on the heater's label. If operating properly, the pump should produce more pressure than is required to operate the heater. The relief valve allows the excess air to escape before being sent to the nozzle. 5. Replace plug. Test for leak. 6. If you are unable to reach the desired pressure spray soapy water around the seal of the end cover- at the same time check the plastic cover for a crack. A cracked end cover will not allow the heater to perform properly and will not allow for an accurate reading. The pump must be set at the specified pressure in order to have adequate fuel delivery an adequate fuel atomization. Replace if needed. 7. If you set the pressure to specs and the heater does not perform properly or the cone does not glow a soft red, then check for other fuel delivery problems such as a clogged fuel filter, cracked rubber hose, clogged or worn nozzle, or a cracked nozzle adapter. Soapy water lightly sprayed in these areas will quickly identify the problem most of the time. Any air leak will create problems.
3/4/2015 6:20:52 AM • Reddy... • Answered on Mar 04, 2015
I have a reddy heater 40,000 btus and it works with the top off but when I put the top piece back on the fan hits it? what do I do
Either the fan blade is loose or the mount is loose, or the outside of the heater has been damaged/dented and hitting the blade. Leaving the top piece off is only an option if there are no pets or children around.
3/1/2015 7:21:20 PM • Reddy... • Answered on Mar 01, 2015
3/1/2015 7:18:57 PM • Reddy... • Answered on Mar 01, 2015
How do i start the unit i purchased it used.
You can download the manual from here: http://www.desatech.com/manuals/Construction%20Heaters/113893-01.pdf
2/24/2015 9:52:23 PM • Reddy... • Answered on Feb 24, 2015
I can not dissconect ols wi fi for installing new
Technology has come a long way. but these heaters don't connect to wi-fi
2/24/2015 3:30:56 AM • Reddy... • Answered on Feb 24, 2015
When the heater is turned up to a higher btu , it cuts off after a short time
What size tank? when it's really cold a small tank will not produce enough vapor fast enough. It could be a weak valve in the tank snap'n shut If the fuel comes out to fast. Could also be high temp switch on back of burner going bad. That happens alot.
2/24/2015 2:57:35 AM • Reddy... • Answered on Feb 24, 2015
How do I keep the reddy heater 55000 btu working inside the house
Probably has an oxygen sensor so you don't run out of air. Probably not something i would bypass in a house.
12/13/2014 12:29:02 AM • Reddy... • Answered on Dec 13, 2014
2answers
Reddy heater 110,000 btu forced air portable kerosene
try this, take off the top cover. plug in the heater and when the humming starts, rotate the fan sharply with a screwdriver. keep your fingers away from the fan. if the fan spins under power your start winding is shot. get a new motor. www dot desatech dot com
11/18/2014 3:23:01 AM • Reddy... • Answered on Nov 18, 2014
I need a photo sensor for a 55,000 btu kerosene heater. model# R55CT/ B55CT
You can find the item at www.desa-parts.com for your R55CT or B55CT Reddy Heater. Here is a link to that item. https://www.desa-parts.com/product/PHOTOCELL-AND-BUSHING-FITS-DESA--MASTER-/PP236
11/10/2014 3:27:32 AM • Reddy... • Answered on Nov 10, 2014
3answers
Is a kerosene heater good for working in my garage
Is it safe? That depends on what you are working on. Having a fire/heat source on the floor is a possibly of an explosion if you have gasoline fuel vapors.
For the most part it is safe, you will smell when you leave the garage, but as long as it is not a real air-tight garage you would be ok.
I run a propane heater in my garage during the winter to get away for a bit. I also have a well ventilated area and don't work on gasoline related items during the winter with that on.
10/31/2014 11:08:09 AM • Reddy... • Answered on Oct 31, 2014
I need to find an igniter for my Reddy Heater 55,
Try www.reddyheater.com . They carry parts for all reddy heaters. I also have a helpful tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which walks you through yearly tune up and repair. Let me know if you more help.
hardrocko
Thanks for using FixYa
10/22/2014 5:37:31 PM • Reddy... • Answered on Oct 22, 2014
I have bought a 200t Reddy Heater M200 and need an owner's manual
they have them here............http://www.portableheaterparts.com/
8/29/2014 4:40:00 PM • Reddy... • Answered on Aug 29, 2014
Allpro SPC30will not stay lit
Check the gas cut out sensor is not faulty.. and there is enough pressure in your gas bottle to operate it..
6/21/2014 8:36:31 AM • Reddy... • Answered on Jun 21, 2014
Reddy Heater-30-55,000 BTU Variable Logo
473 questions posted
Top Reddy Heating & Cooling Experts
Paul Carew
vince
NOEL
NOEL
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Reddy Heating & Cooling
Most Popular Question
reddy heater r35
  • Heating & Cooling
