20 Most Recent
EA - Electronic Arts Freedom Fighters for Windows Questions & Answers
What is code back case
WHAT I WILL DO BECAUSE I WANT TO INSTALL FREEDOM FIGHTER GAME BUT THEY ARE ASKING FOR THE AT THE OF THE CD CASE AND I HAVE LOST MY CD CASE .
How to make it run on windows vista
I have never played this game but I think I know what the solution is.So
this game is designed to run on Windows 95, 98 and ME so this means
that the graphics are 16 bit. Vista uses 256 bit graphics. First thing to
solve this problem. You will need a Graphics card that can support
Graphics from 8 bit to 1024 bit Graphics. You can do this one of two
ways. Either buy a 2 pound graphics card from years ago that will most likely
require a Mother board with an AGP slot and only support 8 bit to 16
bit graphics, or buy a really expensive Graphics card for 2600 pound that
requires two PCI-E slots, a power supply capable of supplying 1800 watts
or more and a DUAL CPU Motherboard capable of taking two AMD 16 core
processors and a minimum of 16 GB of RAM. The Mother Bord would cost
about the same as the Graphics card, the Power Supply would cost around
160 and the RAM would cost around the same as the power supply for the
DDR-3 model, which is what you would need. The Hardware required to
run an expensive Graphics Card capable of running 16 bit Graphics is not
capable of running the software required for 16 bit Graphics on cheap
graphics card.This is the same if you reverse the scenario. A Cheap Graphics Card will not run 16 bit Graphics software with cheap hardware.What you need to do this is both Cheap Hardware and Cheap Software or Expensive Hardware and Expensive software.Old fashioned software will not run on modern Hardware and it is the same for the reverse.
Install code
here ya go PQGY-4FAQ-TMQ5-Q4X8-KXCS P4QQ-T5AQ-T6SD-F5F7-R79V PZ3K-4NAQ-TPZT-Z6WU-ZD2W PW6W-3LAA-TMSA-NBBP-YHCV P866-C4AX-THLC-LGNB-2LWN PGC4-SWA7-T7XN-BU6Y-A6BWPQGY-4FAQ-TMQ5-Q4X8-KXCS P4QQ-T5AQ-T6SD-F5F7-R79V PZ3K-4NAQ-TPZT-Z6WU-ZD2W PW6W-3LAA-TMSA-NBBP-YHCV P866-C4AX-THLC-LGNB-2LWN PGC4-SWA7-T7XN-BU6Y-A6BW
My freedom fighters game ask
kkk firstly..... did u copy paste the crack where the game is installed ....
if u don't have the crack ... download it .. google for it ...
secondly ..... if u have pasted the crack and still asking for cd then u must have installed it from a image using deamon tool or power iso or something like that
soo mount the image . and then start the game .....
hope i works ......
I need a fifa 12 operating
manual
Check here to
the complete
FIFA 12 In Game ManualHope this helps; also keep in mind that your feedback is important and I'll appreciate
your time and consideration if you leave some testimonial comment about
this answer.Thank you for using Fixya, and have a nice day
Give me a mount and blade serial key
H33F-CLBA-JCAR-NYHQ
ARZG-RS43-NTXX-DTQA
FMX4-KWFA-MJCW-MRR3
DDZL-NCMA-HLRZ-KXDK
YDZE HDDJ EYCN XPC7
FMX4-KWFA-MJCW-MRR3
AZFK-XX3M-PP73-9NWY
YDZE-HDDJ-EYCN-XPC7
AZKW-3WJR-YW7L-P9BW
H33F-CLBA-JCAR-NYHQ
YDZE-HDDJ-EYCN-XPC7
AZFR-4QQ3-NNYD-3WHP
GQ4Q-35GZ-2GHK-NBML
72EH-HD83-JDD9-3HWI
H33F-CLBA-RBHA-NYHQ
