Casio FX-9750GPlus Calculator Logo
Posted on Jul 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Im trying to graph a parametric equation and whenever the equation has an exponent/power in it the calculator says Syn error so i know how to graph x=2 cos T, y=2 sin T and similar equations without a exponent but i cant graph x=sin^3 T, y=cos^3 T and also i cant graph x=2 cot T, y=2 sin^2 T because i dont know how 2 enter the cot or exponent without getting a Syn error. could you tell me how to graph these equations on my casio fx-9750G Plus calculator step by step?
k24674
Level 3:
  • Casio Master 8,093 Answers
  • Posted on Jul 26, 2011
k24674
Casio Master
Level 3:
Answers
8093
Questions
0
Helped
4675762
Points
21596
To enter powers of trigonometric functions you must enclose the functions in parentheses and then apply the exponent to the whole. For example X1t =(sin T)^3 , Y1t=(cos T)^3 will give you a shape similar to a rhombus with concave sides. The symbol ^syands for the operation of raising to a power. The key is the one with the caret symbol ^ , and it is wedged between the xsqure and EXIT keys (third row of keys).
As regards the cotangent, use the equivalent definition cot(X)=1/tan(X).
Testimonial: "thank you for your help sooo much u are a life saver and i was able to figure out how 2 graph the equations on my calculator"
Stevan Milanovic
Level 2:
Sergeant:
  • Casio Expert 267 Answers
  • Posted on Sep 27, 2017
Stevan Milanovic
Casio Expert
Level 2:
Sergeant:
Answers
267
Questions
Helped
221987
Points
795
See image below. Its solution for your math problem.
im trying to graph a - 09-27-2017 image001-nxnticqdztek3iig4ztduz5l-1-0_0.jpg
I can not graph a parametric equation useing radians. I am using a TI-nsipre with out any updates since purchase not a CAS or CX one.
In parametric functions, the variables x and y are both functions of an independent variable, called t, and that usually represents the time. The default variable in parametric functions must be called t. You can enter the limits you want. However if you type in 2 Pi it will be converted on the entry line to 6.28. The default tstep is 0.13 which is about pi/24. I fail to see what the commotion is about.
In this representation of the witch of Agnesi, the variable t is between 0 and 4Pi, and the step tstep is 0.13, a little less that pi/24
Reset your calculator and restart
How to graph polar equations
Your calculator does not have graphing capabilities. On a graphing calculator you would first select the graph type 1. function y= f(x), 2. parametric x=x(t), y=y(t), 3.polar r=function(theta).
1helpful
2answers
Syntax error for graphs
This happened to me. I left my calculator open in my bag and accidentally on the 20th function there was a multiply sign, so the calculator would directly output syntax error. Scroll down and check all your function slots are clear.
How do you graph this equation r(t)=cos(t) * i + sin(t)* j + t *k (x,y,z)= (i,j,k) on a ti89
The calculator does not support 3D parametric functions, but there is a procedure that will help you do that. Here is the link to the page that describes it.
1helpful
My fx-9750GA PLUS wont graph lines, cicles or paraballas
Sure it does! Did you ask it to graph?Here are some screen captures to help you find your way.
To draw functions (regular, parametric, polar, sequences) use the application graph: Highloghted on 1st screen capture. The second screen captures shows you the functions y=f(x). enter a legal expression and press F6 Draw. To set TYPE press the key under TYPE.
To draw conics (circles, parabolas, hyperbolas, and ellipses) use the CONiCS applications. (See 3rd screen ). On 4th capture the equation highlight is one for the parabola. y=x^2
Scroll down or up examining the small graphs. They will show you which equation form to choose.
For the circles
I need to generate a graph (graphing trignometric equation in parametric form). The equations are, x=3cos(teta) y=2sin(2teta) We are getting error while generating
At first, you have to use t symbol for parametric functions when you operating with TI 89 Titanium. In your case you must input your relations as x1=3cos(t) and y1=2sin(2t). Then graphing it. See captured image
Trying to draw graph, what does syn error mean? I
Here is a screen capture to help you pinpoint the location of the error.
6helpful
The calculator is only graphing a half circle when it should be a full circle, specifically not in the negative y-values of the plane.
A circle is not a function and cannot be graphed in the regular y=screen. You can graph a circle in parametric mode.
To graph a circle in the regular y= screen, you have to graph it in 2 lines on the y= screen. I assume you've solved for y and gotten a square root equation. Remember a square root can be positive or negative. In line 1 of y= screen graph what you've been graphing and then graph the same equation in line 2 but with a negative in front of the equation. You'll get something that looks like an oval since the calculator screen is rectanglular. To make it look more circular (both parts aren't going to connect), press zoom and then select #5 (square).
2answers
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
