Heating & Cooling Logo
Robert Dehorty Posted on Jul 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Carrier Puron 25HBA336A300 fan on exterior unit will not start but if push started will run and system works normally
Anonymous
Level 3:
President:
  • Master 2,559 Answers
  • Posted on Jul 05, 2011
Anonymous
Master
Level 3:
President:
Answers
2559
Questions
Helped
1213618
Points
9283
The start capacitor for the fan motor is bad and needs to be replaced.
Testimonial: "Thank you sooo much for the fast response"
2answers
My carrier condenser fan has stopped running.can i just pour water over the coil and use the condenser untile the repairman gets here on friday
Messy - why not just hook up a regular fan and hook it up to the power line that ordinarily powers the condenser fan.and have it do the blowing until the repair person comes out on Friday. The ideal fan is one of those old floor fans that used to blow air in a 360 direction.
1helpful
I have 4 ton carrier heat pump / puron. It is a new system been installed about 3 months. Live near Dallas Texas and lately the temp has dropped into the low 40's at night. The heat seems too be working...
The water is from humidity in the outdoor air which has condensed and then frozen to your heat pump outdoor coil. The heat pump will defrost occassionally, depending on how much frost has accumulated to the coil and will then generally drip off the unit and onto the ground. This is normal. To keep the water off the drive way may mean having to move the heat pump to a place where the condensation can run away from the drive area. Or provide some other means of redirecting the water.
2answers
I replaced my whole heat pump system 3 years ago with a Carrier Puron unit. The installer called me this week and told me that I needed to replace the puron after the third year at a approx cost of...
Tell him you already had it done. lol. Unless you misunderstood what he told you no! You don't need to replace the Refrigerant weather it's Puron or Freon. It doesn't wear out. Ever. If your system develops a leak and you loose the Refrigerant it will have to be replaced but you will know you lost it because the system won't cool and heat like it's supposed to. I would report the installer to the better business bureau.
System pressure for puron read 280 and 135 for low side. System is not cooling at all. Suction line at air handler is not cold at all. System has had problems with leaks and customer has told me some...
the system must be leak checked, refrigerant recovered, evacuated, a drier installed, and recharged to the correct subcooling, (I assume this is a carrier since you reference "puron")
the low side pressure seems to be in line the high side pressure would be low depending on operating conditons, these systems must be charged using superheat and subcooling methods, pressures are just a "starting point"
2answers
Compressor fan and compressor not running new 2 yr old system puron
No power to outside unit. Check to see if contactor on outside unit is pulled in. Most AC units inside have float switch. When the drain stops up it shuts off outside unit. Located in overflow or underneath unit. No Problem Rusty
1helpful
Exterior Fan not starting.
Its the problem with the fan. !1 or more coils have burnt out and if repaired will have to rewind the shorted coil/armature. Better to replace the fan. Also when getting it repaired ask them to check the thermostat too...............sodeep
Carrier indoor coil replacement
yup, entire system needs to be drained, and leak needs to be repaired first before charging with freon.
after sealing the leak and test it is ok, evacuate the system for about 30 mins before charging it.
you may need a qualified tech to do that because you can not buy freon now a days.
you need to weld the leak also. you will need portable torch to weld copper pipes.
you will need vacuum pump to evacuate the system before charging with freon 22.
tnx 4 using fixya,
drcool
Carrier air conditioner problem
My Carrier unit did the same thing. It was low on refrigerant (Puron in my unit). I am worried I have a leak somewhere. Hopefully, it is not in the coil. The service call wasn't cheap either. Puron runs around $10-15 a pound and mine took several pounds to replenish.
Carrier 38CKC030348 air conditioner
If the capacitor is bad replacing it is just a mater of moving the wires from the old one to the new one and mount the new capacitor securely in place. In replacing a capacitor it is recommended to replace it with the same rating as the one removed.
If the capacitor is bad it will not prevent the compressor from getting power. Is the compressor trying to start at all. If the compressor is running and you have no cooling the system could have lost the charge of refrigerant.
Top Heating & Cooling Experts
Paul Carew
john h
