Dryer turns and spins,but dosn't blow any heat.we had unplug from wall while cleaning behine washer and dryer.plug back on.turn on two days later.no heat.
If your dryer won\'t heat up the first thing to do is clean out the vent from the back of your dryer up to the roof. (or where ever your vent leads to). You will have to clean it our from both ends. Use a vacuum cleaner that has the ability to switch and BLOW air rather than suck air to blow it through. This usually fixes the problem because there is no air flow and it takes HOURS to dry. If that doesn\'t work then look at the back of your dryer. MAKE SURE IT IS UNPLUGGED IN EVERY EVENT! Then disconnect the wires one at a time and clean and reconnect to make sure you have a good solid connection. Plug back in and see how if it works.
There are a lot of parts to this problem: First don't plug it in again or try to restart it...yet, Make sure before you reset the circuit breaker that you unplug the dryer. So now your home should be fine! The dryer is another story... I have answered this problem for others and with other dryers... Please focus on your washer, there should be very little water that remains in your clothes after the wash cycle and the clothes should Definitely not be dripping. Check to see that your spin cycle is working and if necessary run it through the spin cycle again. You may be overloading the washer. Back to the dryer...NO water should EVER drip from a dryer! If you do not wish to call a service person I would wait about 1 1/2 weeks for the dryer to dry itself and give the dryer another try after that and set it for Air dry only (no heat) if you don't have a problem at that point then stop the dryer and set it for a low heat cycle and try again. I think at that point you should be OK? If you do have problems.. you will have to call in a service person. But please remember clothes should be quite dry coming from the washer before going into the dryer.
Hello. Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator. 1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded. 2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle. 3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes. 4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle. Thanks.
There are several reasons why a dryer would not heat up the clothes.
The vent is plugged with lint or the blower set-screw is loose (blower slips on the motor shaft instead of spinning full speed). If you do not have good airflow at the outside exhaust when the dryer is running, you'll need to check the ductwork all the way back to the lint trap. If the lint trap is torn, repair or replace it.
The heaters are not working due to a bad contact in the timer or one of the two thermostats. Check for continuity in the heater circuit with the dryer unplugged.
The heaters are burned out. Note the plural - most dryers have two heaters, one for low heat, the other for medium, and both for high. Try a different heat setting and see if you get warm air. If you do, the heater you normally use is the problem.
take out all the food out of the freezer,unplug the fridge and get a hair dryer and start melting out all the ice in the freezer,then blow the hot air into the vent holes on the back wall until you don't see any more water dripping down through the slots in the back wall.turn the machine back on,open the fridge door after around 5 or 10 minutes and if you feel cold air blowing into the fridge you fixed the problem,if you don't feel cold air keep hitting the inside back wall with the hair dryer and keep blowing the hot air into the holes in the back wall.all that it does is the freezer gets cold and there's a fan behind the back wall in the freezer,the fan blows the cold air into the fridge side,if the air ducts are frozen the air can't circulate into the fridge section so you have to melt the ice out so the cold air can blow from the freezer to the fridge.good luck,if you have another fridge remove the food and unplug it and leave the doors open for a day and it will melt out.good luck
You vent is plugged very bad. Disconnect the vent tubing and thoroughly clean it out. It will heat and dry like new afterwards guaranteed. These dryers have sensors that shut the burner off if the exhaust is not venting properly. Once its cleared out it will run perfectly again
It sounds like your heating element is burnt out will will need to get someone out there to check and repair it they can open up the back of your dryer and check the parts with a ohm tester.......
Turn the dryer on, go out to the where the vent exits the house. Feel the air coming out, and it should blow very strong, and for the total diameter of the discharge. If it doesn't, the vent pipe is plugged, or the connection hose from wall to dryer is crimped/collapsed when pushed back to the wall.
Also make sure lint filter is clean, and the grill inside the dryer where hot air enters is clear.
Sounds like you have a ventalation problem. The clothes heat up, but without airflow, the moisture remains. First check the hose from the back of the dryer to the wall. Is it plugged, kinked, or restricted? No? Turn your dryer on and remove the hose. Do you feel pressure coming from the back of the unit? No? You need to take it apart and clean the internal airway. If you do feel pressure, reconnect it to the wall and start your dryer. Walk to the outside of the house. Do you feel a fair amount of air coming out? No? There are companies that will clean your vent in the phone book. There are also vent cleaning brushes you can buy at hardware and appliance part stores.
