Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
Posted on May 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water is leaking into the refrigerator from the freezer it seems to be worse when the ice maker is on
Sal De
Level 3:
  • Whirlpool Master 2,699 Answers
  • Posted on May 11, 2011
Sal  De
Whirlpool Master
Level 3:
Answers
2699
Questions
0
Helped
1003374
Points
8029
If it's worse with the ice maker on i'd have to say the ice maker is leaking but normally the water is from a blocked drain in the freezer.unplug it,remove everything out of the freezer,pull off the inside back wall of the freezer,melt out all the ice with a hair dryer,next you'll see a hole under the evap coil,that's the drain,you have to free it up,i use a steemer to blow down through the drain but if you don't have a steemer keep heating up the area where the drain hole is,you can try using a turkey baster to blow through the drain,when you think the drain is clear pour hot water into the drain hole,if it goes down you're done,if it doesn't keep heating it until the water drains down the hole.also open the fridge door,in the top of the fridge in the middle of the ceiling and where it touches the back wall you'll see a mold,that's also the drain,heat that area up with the hair dryer to melt out the ice in the drain.the problem is slime builds up in the drain,when the fridge goes into defrost the heater comes on and melts the ice off of the evap coil and the water goes down the drain and into the drip pan on the bottom of the fridge,your drain is blocked and the water is leaking into the fridge,the drain has to be cleared.good luck with your machine.if i can help you with anything else let me know.
Ice maker drips water into freezer.Makes ice but doesn't shut off when full.
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
Aug 6, 2015 - If the ice maker doesn't make ice but you can see the arm swing intomotion and you hear a ... 4Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, ... If your ice maker keeps making ice, even when it is full:.
Refrigerator's Ice Maker Leaking Water ' ThriftyFun
www.thriftyfun.com/tf37813274.tip.html
If your refrigerator ice maker is leaking water, the first step is to locate the source. ... Its not the ice maker - in the floor of the freezer is a small drain that lets the ... I shutthe water supply off but water dispenser still leaks even though no ... My side by side refrigerator leaks water into the ice bin when filling the ice tray with water .
Kenmore model 106.72009010 leaking water onto floor
Defrost is not working and that is causing the leak.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
The freezer has an obvious leak. When we wait a few days, we can see that water leaked into the freezer and it turned into a large brick of ice? What does that mean?
Hi Monica,
This seems to be a problem with overflow of water into the ice maker, or a leak in the feeder to the ice maker. My suggestion is to turn off the ice maker by raising the lever on the unit, and see if the ice re-accumulates. This would mean that the water is leaking from the inlet, and the ice maker has no obvious fault. If you find this, you can remove the ice maker from the freezer by removing the screws holding it to the inside, unplug the unit from the back of the freezer, and pull straight out. Look at the inlet of the water at the rear of the freezer and see if there is a break in the line or a crack somewhere along it. You can replace it from the back of the refrigerator itself, going from the bottom where the water is hooked up to the top by removing the panel that guards it.
I hope this isn't too confusing.
Joe
Ice maker leaking
Are you sure it's the ice maker that's leaking? We have this model & ours accumulates a HUGE iceberg in the bottom of the freezer, but the water seems to be coming out of the back, at the bottom of the back panel, where the vents are.
Kenmore bottom freezer refrigerator warming up
Hi
There is a definetely leak in the cooling gas.
Firstly... You will need to find from where the gas has leaked. It is usually on the compressor pipes..... but not always.
Secondly you are right about the Water Valve... it needs to be changed.
Regards
Berry
Ice building up in the bottom of the freezer
The water supply line is leaking.Put some paper towels down after you clean up and check real often to back track where leak is coming from,maybe your ice maker is over flowing with water.When was the last time you replaced your water filter?Could be backing up,just replaced mine,it was leaking under the fridge,mine is a Sear's Kenmore,ordered a filter from Sear's,Cost me 50 buck's,My filter is at the bottom front,your's may be inside the freezer.
1helpful
Fridge leaks water when Ice maker is activated by lifting lever
Either a loose or broken hose , or worse, a crack on the water valve.Pull fridge and check water valve and hose when signal calls for water.
Water dripping in Freezer leaving ice all over food
need a new ice maker for the leak but the temp is another thing
Ice maker is leaking into the tray where the ice is dispensed causing the ice to become embedded into the tray
there is a screw in the ice maker unit that can adjust the water level open the ice maker whit cover and you should see it but turn it gently little by little each time...and see how much you getting :) very EZ good luck
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
