SOURCE: 12'' Ryobi miter saw with loose blade
You may need to use lock tight on the threads. Also replace the standard washer with a lock washer if possible.
SOURCE: I've been using dewalt miter saw dw715 for several
This is common IF the blade clamping nut becomes loose... the blade will free wheel on the arbor after the motor stops. It can tear up the arbor so investigate this possibility immediately.
SOURCE: dewalt miter saw .
Either the blade or the guard is out of alignment. You will have to check and find out which one is the culprit.
SOURCE: DEWALT DW705 MITER SAW BRAKE DOES NOT WORK
Could be worn brushes, dirty commutator or a combination of both. Unplug the tool and remove one brush at a time noting the condition and length. Use a flashlight look into brush tube and also not condition of commutator. I would blow is out with compressed air and you can try turning the brushes 180 deg and retry. That is usually the problem
