Timex 27191 Wristwatch Logo
Posted on May 15, 2008
Cannot re-attach back cover - WR30M
After replacing the battery, I cannot reattach the back cover of the watch.
Any suggestions?
  • 7 more comments
  • 2ktwo2 Jun 11, 2008
    Have applied every sort of pressure to the back of a larger size ladies Timex, and can't for the life of me get it to snap in place.
  • Anonymous Jun 18, 2008
    Also can not get back on.
  • Anonymous Jun 30, 2008
    I can't believe nobody has a solution for this. I've been trying to re-attach the back for hours! Somebody help! ruddrunner
  • Anonymous Jul 17, 2008
    I give up....hours wasted trying to get back cover on...Never had this problem before...There is a little arrow on cover...what should it line up to? I may duct tape the battery in and then duct tape back on til i can get to store to buy replacement....and it won't be a Timex...not after this headache!!.
    [email protected]
  • Anonymous Jul 23, 2008
    can not get back cover watch
  • Anonymous Aug 18, 2008
    I had never had this problem with Timex before I bought this one about a year ago. Threw it in the trash after trying all day to put the cover back on. Will never buy another Timex.
  • pronepositio Nov 25, 2008
    Used a 2inch c-clamp and got it closed. The only problem was the diameter was not the same so there is a little concave on the cover and half the gasket repeatedly came out so I ripped it off. No showers for this watch.
  • elnonameo May 26, 2009
    I used a vice - but it cracked the circuit board inside - now, it's trash
  • Anonymous Mar 20, 2014
    The light will not turn off and the battery is running out
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 11, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
25177
Points
23
Yeah, I had this problem on a Timex Indiglo, but didn't have it on the cheap $20 watches in drug stores and discount stores. Timex puts a tighter cap on the back, probably for quality reasons, and you cannot push it together by your thumb. --This solution should work for about anyone: 1. Put the watch face down on a hard surface, but protect the crystal from scratching by putting a piece of cardboard or cloth between them. 2. Align the back and put a socket from a socket set on it that is somewhat smaller than the back cap. 3. Tap the socket with a hammer. You don't need to tap hard--even less than what would start a small nail. It may take only one tap--getting it aligned right is the key.
  • 2 more comments
  • cpepvine Jul 18, 2011
    ok fellow home made repair friends....I replaced my battery on my Timex . Wal-mart...they don't put battery back UNLEss you buy the watch there. But anyway. To replace the back end of Timex watch I used soft pad(mouse pad) and flipped it glass side down and got a soft cloth and
    got a hammer and wacked the backside of the watch, took several times each time looking closely. and hitting it few more times then it went back in...cool
  • Anonymous Feb 16, 2013
    Hubby just figured it out -- put one side in place, then use vice-grips or pliers to "press" on the other side of the back. Works perfectly.
  • Anonymous Apr 19, 2017
    Yeah, even with a thick soft cloth, I cracked the crystal. This Timex design SUCKS. Never again. I'm going back to an Eco watch - no battery - runs off of body movement.
  • Gretchen Lewis
    Gretchen Lewis Nov 24, 2017
    I put a hose rubber washer over crystal, used pliers, easy!
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Aug 15, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
26723
Points
17
I had this same problem. To reattach the back, align the arrow on the back with the center of the band (either top or bottom). The arrow points to a "lip" on the case where a small screwdriver or pocket knife may be used to pry off the back. Once in place, I pressed it firmly and then used a rubber mallet to strike the raised edge smartly and it went back together. I tried many times to use my fingers but could not apply enough pressure to connect. I tried calling Timex but they were closed for lunch 20 minutes passed the recorded time. Must be nice. Anjyway, a jewelery would use a cushioned clamp that may be tightened to snap the back in place. Perhaps a small wooden Jorgensen clamp would work too.... .
Anonymous
Level 1:
  • Posted on Aug 30, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
25177
Points
I had this problem, too. After an hour of trying, I taped the back of the watch on (so it wouldn't slip off), wrapped the watch in a tissue to prevent scratches, and then put the watch in a wooden vise clamp. I tightened the vise until I physically couldn't tighten it anymore, and then FINALLY it snapped into place! Good luck finding a vise!
Anonymous
Level 1:
  • Posted on Apr 29, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
25177
Points
Success, I finally got the back on the watch by using a 2" C-clamp and two pieces of wood to cushion the watch. Had to tighten really hard and was afraid the crystal would break but it did not. The back finally snapped into Place!!!!
OF COURSE THE WATCH NO LONGER WORKS, BUT THE *&^% BACK IS ON!
Anonymous
Level 1:
  • Posted on Mar 24, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
25177
Points
I had the same problem. Frustrated trying to put the cover back on after changing the battery on my timex indiglo fro Walmart that stopped working 105 days after the 90 day money back warranty. Tried pressing on for over 30 minutes with my thumbs, palm of hand etc. Wouldn't pop back on no matter how hard i pushed. Folded a papertowel into 4- 6 folds, reversed the strap over, put the papertowel between the glass and the strap, put it on the floor, put a large nut slightly smaller than the cover diameter, tapped on the nut with the flat head of a handless-axe. The cover snapped back on on the fourth hard tap. I did put some white vaseline jelly on the gasket and wiped it off with a papertowel.
Anonymous
Level 1:
  • Posted on Nov 06, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
25177
Points
I used a combination of the above solutions: socket from a socket wrench; cover with rubber mallet instead of sledge hammer, and hit with the palm of my hand.
I looked at the Timex web site and couldn't find any answer at all... Looking at the Problem listings above was reassuring that I wasn't the only one having a terrible time with it.
I am soooo happy I found the FixYa site for very creative solutions.... Thanks again!
cinchan
Level 1:
New Friend:
  • Posted on Jun 03, 2014
cinchan
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
25177
Points
I had the same exact problem. Spent almost an hour trying to reattach the back with no avail till I found this site. I used a combination of everything. I put a bit of vaseline along the gasket and placed the back in the same direction as before, i.e. the arrow pointing to 1 o'clock. I then sandwiched the watch with a towel/dish cloth and used two pairs of pliers. I'm right handed, so I held one pair with my left hand to hold it steady and in place, and the one in my right hand was to put pressure until it clicked. My trick was to put pressure not in the middle, in order to prevent the glass from breaking, but more to the edge. It kept popping back up so it was really a struggle. But after a while it worked. Note: You need a lot of perseverance!
Anonymous
Level 1:
New Friend:
  • Posted on Feb 22, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
25177
Points
All - thanks for sharing your frustration with Timex watches. Just discovered that using a 'robo-grip' hand vise tool - or anything that puts pressure in the center of the watch's back - will destroy the watch's mechanics. Scrap one watch. Used a wooden vise (w/a thick pamplet) on the second Timex watch I was trying to get the back on, and that worked though not perfectly.
Anonymous
Level 1:
New Friend:
  • Posted on Dec 20, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
25177
Points
We put s tiny amt of silicone grease on the tiny o ring and case edge(water proofing and friction reducing). We used a 11/16 socket which was the outside diameter of the case back. I lined up the case back so it was evenly flat to the watch. Face down on a rubber mat(mouse pad. One mild tap with as plastic faced lead shot filled mallet. done!!
Anonymous
Level 1:
  • Posted on Sep 26, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
25177
Points
I had the exact same problem. Finally after all day messing with it I took out the plastic rim from the inside, aligned in the back piece and then put it back together with the arrow pointing at the top center like stated above. Then I took a cloth put in on the face of the watch folded over and used one pair of pliers to push down on one side and then held in place while I used another pair of pliers to push on the other side and it finally snapped in. FYI - Walmart will put the battery in for you if you buy the battery there since they sell Timex watches. Wish I had done that instead but I didn't want to make the trip over there. Next time I will!
Anonymous
Level 1:
  • Posted on Nov 26, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
25177
Points
I had the same problem, frustrating! I used the solution posted on Oct 11, 2008 by JakeOfAllwith a 7/8" deep socket and full-sized hammer. It did not require much of a hit.
Anonymous
Level 1:
  • Posted on Jan 14, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
25177
Points
Well I use to work in a store that sold batteries and timex watches, and to be honest with you the way I use to fix this problem was with a big pair of vice grips. I'd put the watch in them and slowly turn the vice grips until I heard the watch pop back into place. I did this a ton and never broke any watches :)
Francisco Cantoran
Level 1:
New Friend:
  • Posted on Jun 30, 2014
Francisco Cantoran
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
25177
Points
I had the same problem as everybody else here, Once I replaced my battery watch I could not put the back of the watch back on, I placed a kitchen towel folded it like four fold on a flat surface found a wrench socket a little smaller than the back of the watch gave it a couple hits on the back of the watch and it was back on, I also put some oil on the groove of the the watch back, i guess that helped too, Hope this helps you too
Claudia Williams
Level 1:
  • Contributor 4 Answers
  • Posted on Nov 14, 2013
Claudia Williams
Contributor
Level 1:
Answers
Questions
Helped
28613
Points
The towel on the table, crystal side down, nut and hammer tap worked for me!
Anonymous
Level 1:
New Friend:
  • Posted on Dec 11, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
25177
Points
Turned a metal shot glass upside down on the counter, carefully aligned the back ont the watch and placed the watch face up on the bottom of the shot glass and pressed down firmly on the face with the palm of my hand and it snapped in. Worked for my Timex Expedition
Anonymous
Level 1:
New Friend:
  • Posted on Apr 23, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
25177
Points
Throw it in the trash it's a timex that's where it will end up anyways. After 2 hours I used a clamp to try to put it on..bent it so I smashed the watch with the clamp.
Anonymous
Level 1:
  • Posted on Jan 02, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
25177
Points
Yea, my whole family tried for about an hour to snap the back on so looked up this sight and folded some paper towels to put under crystal then socket, tried three medium hammer blows then knocked the hell out of it back went on but no second hand when I turned it over, threw the *^&##@ thing in the trash, NO MORE TIMEXS for me
Anonymous
Level 1:
  • Posted on Aug 08, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
25177
Points
In addition to the C-Clamp we used a metal ruler to spread the force evenly on the back of the watch and an envelope to protect the front crystal. Tighten the clamp and hear the slightest "click" and it's on!
Anonymous
Level 1:
  • Posted on Dec 18, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
25177
Points
BOBAR is exactly right. I used a socket the same size of the out side edges with layers of cotton protecting the front and one good shot with a hammer did it. Thanks Bobar
A
Anonymous
Had to replace the battery in my watch, too. Couldn't get the back on like the rest of you. I gave my watch to our maintenance manager at work. After trying feverishly for about 15 minutes, he laid the face of the watch on a heavy duty welding glove. He then took a 3# sledge hammer - - - not what you think!!!!! He put the HANDLE on the back of the watch and hit the head of the sledge with the base of his palm. He had to do this 3 times, but the back of the watch popped in place and I hope this battery lasts 5 years like the original one did.
Anonymous
Level 1:
New Friend:
  • Posted on Jul 15, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
25177
Points
Hey my name is Matt and I work at a small hardware store in Columbus, Ohio I had a customer bring me a Timex wristwatch and I had the same problem getting the cover back on. After playing around with it I was able to tap the cover back on using a very small lightweight ball pein hammer. On the cover there was a small arrow pointing to an impression on the side, I simply placed it in the exact position it was in originally and then gave it a firm tap with my hammer and it snapped into place.
A
Anonymous
Buy a new one. I hate Indiglo watches. They've always been a pain in the A$$.
1helpful
2answers
Timex Indiglo Wr30m. Why is the alarm not ringing in my WR30M sports watch?
Maybe the battery doesn't have enough power for the sounder.
Oct 27, 2023 • The Watches
How to set the time on timex WR30M watch?
hi Janet.
You may also need to change the time when traveling or to adjust for daylight saving time.
  1. What to Look For. Locate the MODE button, the SET/INDIGLO button and the START/STOP button on the side of your Timex Indiglo WR 30M.
  2. Setting the Hours. Press down the MODE button until "TIME" appears. ...
  3. Setting Minutes and Date
https://oureverydaylife.com/how-do-i-change-the-time-on-a-timex-indiglo-wr-30m-12421830.html
How to set the time on timex WR30M watch Google Search
Where can I get a battery for a Ohsen wr30m Watch?
Easiest way is to take watch to a watch repair, jewelry store, or big box store like Walmart. They can sell you that battery and install it for you.
To determine the battery type, you will need to refer to your manual, or you can try looking on the back of your watch (which sometimes lists the battery type.)
Apr 01, 2015 • Watches
My Timex Indeglo watch does not have any means of opening the watch so I can replace the battery. It kept perfect time when it ran, but now it does not run at all. Is it supposed to be a disposable watch...
  • If you don't already know what size battery you need, you can find this information on the back plate of your watch. Once you have your replacement battery, you will need to open the back of the watch to gain access to the battery compartment. Depending on the watch, the back plate will either screw off or be attached by a few small screws. If attached with screws, you will need a set of precision screwdrivers such as a jewelry or eyeglass kit.
    Inside the battery compartment, you will see the battery is held down by a clip. Carefully remove the clip and eject the battery. Insert the new battery and replace the clip. If the battery clamp indicates you should do so, quickly press the reset button twice. Then reattach the back of the watch. If the watch display remains off after replacing the battery, press all buttons at the same time to reset the display.
  • 1helpful
    I have a small acqua watch and after replacing the CR1612 battery i can't seam to get the cover back on. there is no notch on the back cover so orientation may be a problem. the only markings on the back...
    I suggest that arrow points to where the case back should be opened. Check if there are any writings on case back. When the watch's opened back is facing you (winder to the left), these letters should be normally readable (not upside down) with case back attached to watch. If there are no writings, check inside case back - there should be small groove on one side. This side should be aligned with the stem (the piece going from winder into watch).. Hard to say without seeing it, but hope it helps. Be aware: to fit the case back back on watch may require significant force.
    How do you remove back cover to replace 296 wrist watch battery
    Thank you for contacting FixYa.
  • Place the watch face-down on a clean towel to protect the crystal.
  • 2
    Gently unscrew the backplate from the watch with a small jeweler's screwdriver and set it aside.
  • 3
    Locate the battery compartment and remove the screw holding the cover in place, using the screwdriver. The battery is a small, round silvery button.
  • 4
    Make a note of the battery polarity before you remove it. Is the battery positive (+) side up or negative (-)?
  • 5
    Take the battery with you to a watch shop or electronics store to buy a replacement.
  • 6
    Insert the new battery in the compartment. Replace the battery cover and reverse the above steps to reattach the back cover of your Peugeot watch
  • 1helpful
    How to change battery
  • Spread the towel out on a flat surface.
  • Remove the watchband if necessary in order to access the back of the watch.
  • Unscrew the back protector from the watch using the correct size miniature screw driver. Place the screws in a small pile on the towel. Be careful not to drop them as they are difficult to find.
  • Remove the back plate by unscrewing the small screws. There is a tiny spring on the underneath of the back plate. It may be visible, or not. Make sure not to turn the watch upside down or the spring will dislodge.
  • Remove the rubber protector to find the battery.
  • Use sharp point tweezers to remove the clasp covering the battery. There is a small hole at one end of the clasp. Insert one end of the tweezers into the hole to spring the clasp loose.
  • Remove the old battery with tweezers.
  • Insert New Battery and Reassemble Watch
  • Pick up the new battery using regular tweezers and put it into place. Do not touch the battery with your fingers.
  • Replace the clasp over the top of the new battery.
  • Perform a reset by touching the AC contact with one part of the tweezers and the back of the battery with the other part. Hold for a few seconds. Lift the watch carefully and look up at the front to make sure the watch is working. Do not turn the watch over.
  • Replace the rubber cover.
  • Replace the back plate by screwing the small screws back into place.
  • Replace the back protector by screwing the small screws back into place.
  • Reattach the watch band to the watch face.
  • Feel a bit unnerved by this? Find a local jeweler. Best regards.
    Jewel
    The back doesn't seem to want to snap back in
    Try a very small dab of a very light lubrican on the sealing edges.
    If you haven't already tried it, press the edge of the watch back using two fingers and move them appart until they meet again.
    Season with a lot of parience... good luck!
    Top Timex Watches Experts
    Paul Bade
    NOEL
    NOEL
    Ngoro
    Are you a Timex Watch Expert? Answer questions, earn points and help others
