20 Most Recent
Timex 5B841 Wristwatch Questions & Answers
How do I change time on timex watch?
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
- Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
- Press ADJUST to set SECONDS to zero.
- Press START/STOP to select MINUTES.
- Press ADJUST to change.
- Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
- Press MODE when done.
- To display DATE from Time display , press START/STOP.
- With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
- With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
- Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
- Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
- Press ADJUST to change.. Press MODE when done.
- Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
- Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
- With time displayed, press MODE to select Chrono Mode.
- Press START/STOP to start.
- Press ADJUST to view lap time. Press again to sesume lap timing.
- Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
- Repeat for successive laps.
Have fun! - Not a bad watch for the money! - - Silver Bullet
Well the problem is that
Hi Krystal,
Timex has two ways to find information about your particular watch. Some of these models only have a guide consisting of a few pages. If your watch is the 1440 series, the following info may help you. If you don't have the manual, Try this link:
If your watch is the W-207 movement use this guide:
http://assets.timex.com/user_guides/W207_M115/W207_M115_NA_EN.pdf
Complete Timex link site:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Now, look up the model number, or if you cannot find that, check the three-digit Module Number from the back of the watch. Click on it in the Module Table, and download a PDF of your watch setting-instructions/manual.
If you need more specialized help, call Timex in Little Rock, Arkansas at 1-800-448-4639.
I hope this helps you. Thanks, Bill
How do i set time
mcdevito75 here, You need the MODE and SET buttons right now, Press Mode, you may have to hold down the mode button 2-3 seconds, now see display flashing, now press the set button for each funtion you want, hour, minute etc. after each function is set press mode to move to the next function, when all functions are set presss mode again to seee steady display. If needed here is Timex customer service, 800-448-4639 Hope this helps.
How do i adjust the date on my classic watch
You have to adjust the date every February (28 or 29 days), April, June, September and November (each 30 days). Self adjusting calendars are called Perpetual Calendars and this feature is quite expensive, especially in mechanical watches. Your watch has calendar ring with 31 days printed on and the simple calendar mechanism which is changing dates from 1 to 31 inclusive,day after day, so, when the 30-day month is ending and there is no 31st date to follow, your calendar is showing 31st anyway,instead of 1st of the next month. This is when you have to adjust date. Now about the date adjusting. If you pull out crown gently, you will notice there are two clicks (positions), not just one. So the first click, when crown is not pulled out fully, is exactly for day/date adjustment. If you pull the crown further out, watch is in hand adjustment mode. Try it carefully and you will find out the right position.
Rate me, please.
Timex watch model 1440 sports
http://www.timex.com/gp/node/n/255235011/178-1795200-7359408?ie=UTF8&timexBrand=core
This link will take you to the official Timex page where you can download the instruction manuals for any of their watches.
How?
Since I'm not sure which Timex you have here's the easiest thing I can do for you:
Battery replacement Timex T2H381
This will depend on the back of the watch. Totally smooth watch back is usually a push fit. Using a small precision screwdriver you Gently lever around the back plate until it 'Pops' off. the battery should hook out by CAREFULLY using the screwdriver you used to remove the back plate. *Note* check which way up the battery is fitted BEFORE you remove it. The back plate should just push on and should quietly click when seated correctly.
Some back plates are 'screw on'. You can usually spot these by the dimples or notches on the back plate where the removal tool fits.
Manual for timex TW4B02500CS
Instruction Manuals, User Guides and Downloads
timex.cahttps://www.timex.ca
Celebrating 165 Years of Innovation in Timekeeping. Discover More From Timex. Free Standard Shipping. New & Classic Styles. Styles: Metropolitan+, Waterbury, One GPS+, Weekender, Expedition, Intelligent Quartz, Originals. Shop Best Sellers.
Rating for timex.ca: 3.7 - 209 reviews
- Return policy: Most items 30+ days
Expedition North TitaniumBuilt With the Strongest Materials, Shop The Expedition North Titanium
Timex® New ArrivalsShop Our Newest Watches & Enjoy Free Shipping Worldwide.
Shop Marlin® Sub-DialA Modern-Retro Update To Our 1960s Marlin. Sharp Enough For Any Outing
Search Results
Watch Instructions & Manuals
Timex
https://www.timex.ca > watch-manuals
Instruction Manuals, User Guides and Downloads. Search for documentation for your Timex by entering the name, product number or feature. Sort by name ...
Timex M EXPEDITION GRID SHOCK WATCH, ... - manualzz
manualzz
https://manualzz.com > Fashion & style > Watches
View online or download PDF (301 KB) Timex M EXPEDITION GRID SHOCK WATCH, TW4B02500 Instruction manual • M EXPEDITION GRID SHOCK WATCH, TW4B02500 watches ...
