My Father-in-law gave me a Vizio VX37L HDTV10A. He siad he shut TV off one morning and went to turn it back on that evening and it wouldn't come on. The Vizio emblem in middle of TV is amber colored then when Tv power button is pressed it turns white but nothing comes on. No picture or sound. Ideas?
SOURCE: VIZIO vx37l tv remote control code for cox tv remote
0178 will work but you have to keep the set-up button pressed down for more than a few seconds after you press TV on your cox remote. (You will see the tv button light up 2 or 3 times after pressing it and holding the set-up button down)
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
SOURCE: only vizio light on
RJW34 I have a 37" Viizio LCD that has a similar problem. I power it up and I get a lit screen but it's blank. No controls work except power on and off.
SOURCE: Vizio VW32L HDTV10A stopped responding with Vizio
Change the batteries in your remote. If your cat was laying on a button it could have drained them.
Here's tip - you can use your camera on your cell phone to see the IR signal coming out of your remote. Point the remote at your cam and press "On" or any button. You should see a bright flash with every key stroke.
SOURCE: tv clicks on and off for 1 min.. till it turns on
shut off your copier and let it rest for 10 mins.. and turn back on,
if it is still no good, call for repair!
