Samsung LN-T4061F 40 in. LCD HDTV Logo
Posted on Nov 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 40 inch Samsung Tv does not have a clear picture. Comes out lookin pychedelic. Red, green, and blue.
Anonymous
Level 3:
  • Master 458 Answers
  • Posted on Nov 10, 2009
Anonymous
Master
Level 3:
Answers
458
Questions
0
Helped
217503
Points
1225
Try cleaning t-con board to lcd panel cable..........
if sam problem just replaced lcd panel
Color is not right. Things suppose to be blue are green and peoples skin is red
HI,
Probably the t con board is faulty. if its 32 inch tv then you would be luck if you find a septate t con board rather than one which is integrated to lcd panel. . if its 40 inch or above you will surly find a separate t con board .
check the video too
HOW TO REPAIR SAMSUNG TV WITH BAD PICTURE como reparar samsung tv...
www.electro-medical.blogspot.com
Dlp tv color goes fuzzy and green
Its probably unrelated to lamp, take the lamp out, try it again and look into the lens, if its still very green the projectors electronics are failing. The projector generates pictures as 3 streams of info Red Green and Blue. It looks like the projectors red and blue electronics are failing, but the green is working.
Samsung LN-T4071F picture starts clear, then gets grainy as the TV stay on.
I have samsung TV 40 inches flat screen comes on the picture ok but within 10 minutes the picture goes black and white
Clear but only blue/green color
Do you have a component cable hooked up to the TV? (cable with RCA connections Green/Blue/Red/White/Red)
If so you want to check that the red cable is tightly connected to both ends (TV and whatever it is connected to).
Good Luck...
2helpful
RED COLOR NOT coming on TV, showing green all over place
I also have a samsung 40 inch. Try hitting the menu button on the remote the scrolling over to the right once and scroll down and hit pictures reset to see if that works. If it doesn't check your connections coming from the back of the source and the tv itself.
Why am i getting a blue screen on my samsung 40 inch tv..i have just set it up and the picture is clear but it is blue!!
Are you saying that you are getting a picture but it has a blue tint. Is this on all inputs. If just on the Component 3 wire video inpit check that cables are correctly matched .
Samsung HLP5063 the blue and green seem misaligned
you have what they call guns in the back of the tv blue/green and red and sounds like they have came out of adjustment. as far as the picture being black and white you should get a tv technician to check it
Image problem
Its only 3 month old, so its still under warranty. Yes, its a major problem.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
