There might be two possible reason for that.
it might be coming form the tub itself passing through the rubber seal of your plastic rotator(the big wheel inside the tub)
the other thing is in the junction of the hose the tub.
try to open the back of your washing macjine where you can get an access inside the wheel and the junction connector, from there you will the cause of the leackage. try to put some water while looking at so you can see where the water is coming out
I have a cabrio washer and i have noticed that water is dripping inside the tube when it is off. anyone else having this issue and no how to fix it?
Take the back off, check the hoses up top coming from the little dispensers. if one of the hoses is broken, that will be where the water is leaking from.
If the washer leaks all the time, check these:
If the washer leaks only during the fill cycle, check these:
SOURCE: hotpoint G-157 washer
get a small putty knife facing the machine insert it about 2 inches from the edge in the little crack between the top and body of the washer push in while lifting the top you should feel the spring that should get the top up but prob you have a leaking tub seal
SOURCE: water leaking from under the front of the washing machine
The pump is easy to replace:
#1 Use a shop vac and pull all the water out of the drain line. This will keep you from having to clean up about 1 gallon of water off of the floor.
#2 Lift the front of the machine enough for you to get under and see.the pump just inside the front of the washer.
#3 Lift the 2 retaining clips off of the pump. This will allow you to pull the pump off of the motor.
#4 Remove the 2 clamps off of the hoses.
#5 Install the new pump into the hoses, and reinstall the clamps.
#6 With the retaining clips installed into the motor housing, install the pump.
#7 Attach the retaining clips, and set the washer back on the ground.
You have now replaced the washer pump.
If you have any questions, let me know
