Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Posted on Sep 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
F54 error code
I have a Whirlpool Cabrio washing machine, model# WTW6600SW2. When I start any cycle, it will start to fill and then I get an F54 code. What does this mean?
Thanks.
Karl Wright
Level 3:
President:
  • Master 1,653 Answers
  • Posted on Oct 02, 2009
Karl Wright
Master
Level 3:
President:
Answers
1653
Questions
Helped
759019
Points
4902
The F54 code is a motor control overcurrent error. If you keep seeing this error then you ned to callin a service man to have the system looked at.
  • kip hooper
    kip hooper Dec 30, 2013
    mine is a maytag and starts to go to full spin then stops and gives f54 code
Whirlpool Cabrio WTW6700TW1 skips wash cycle and stops after 14 minutes to oL
oL is an Overload error. Try running a cycle empty.
If oL (overloaded) appears in display, the load too large. If an overload is detected, the washer will drain any water and detergent in the washer. Remove several items and add HE detergent. Close lid and press START/PAUSE.
oL - Error Code - Washer - Product Help ' Whirlpool
https://www.google.com/search?q=whirlpool+cabrio+ol+error
How do i fix the Ld code on a whirlpool cabrio top load washer WTW6200SW2?
Troubleshooting Cabrio, Bravos, & Oasis Washer Problems Cabrio, Bravos, Oasis Washing Machine Overview
Washer Components
Diagnostic Mode & Tests ' Tips & Tricks Error Codes LF ' Ld ' uL ' oL ' Sd ' lid ' Po ' HC ' dL ' dU ' F1 ' F2 ' F30 ' F32 ' F40 ' F41 ' F50 ' F51 'F52 ' F53 ' F54 ' F70 ' F71 ' F72 ' F80 ' F81 ' F82 ' F83 ' F84 ' F85Always disconnect the washing machine's power supply before working on the appliance!Washing Machine Models That ApplyWhirlpool Cabrio Washing Machines
WTW6200SW0, WTW6200SW1, WTW6200SW2, WTW6200SW3, WTW6200VW0, WTW6200VW1, WTW6300SB0, WTW6300SB1, WTW6300SB2, WTW6300SG0, WTW6300SG1, WTW6300SG2, WTW6300SW0, WTW6300SW1, WTW6300SW2, WTW6300WW0, WTW6340WW0, WTW6400SW0, WTW6400SW1, WTW6400SW2, WTW6400SW3, WTW6500WW1, WTW6600SB0, WTW6600SB1, WTW6600SB2, WTW6600SB3, WTW6600SG0, WTW6600SG1, WTW6600SG2, WTW6600SG3, WTW6600SW0, WTW6600SW1, WTW6600SW2, WTW6600SW3, WTW6700TU1, WTW6700TU2, WTW6700TW0, WTW6700TW1, WTW6700TW2, WTW6800WB1, WTW6800WL1, WTW6800WW1 WTW7300XW0, WTW7340XW0, WTW7600XW0, WTW7800XW0
Maytag Bravos Washing Machines
MTW6300TQ0, MTW6300TQ1, MTW6400TQ0, MTW6500TQ0, MTW6600TB0, MTW6600TB1, MTW6600TQ0, MTW6600TQ1, MTW6700TQ0, MTW6700TQ1, MVWB300WQ0, MVWB300WQ1, MVWB400VQ0, MVWB450WQ0, MVWB450WQ1, MVWB700VQ0, MVWB750WB0, MVWB750WB1, MVWB750WL0, MVWB750WL1, MVWB750WQ0, MVWB750WQ1, MVWB750WR0, MVWB750WR1, MVWB800VB0, MVWB800VQ0, MVWB800VU0, MVWB850WB0, MVWB850WB1, MVWB850WL0, MVWB850WL1, MVWB850WQ0, MVWB850WQ1, MVWB850WR0, MVWB850WR1
Kenmore Oasis Washing Machines
110.27092603, 110.27092602, 110.27092601, 110.27092600, 110.27087605, 110.27087604, 110.27087603, 110.27087602, 110.27087601, 110.27087600, 110.27086605, 110.27086604, 110.27086603, 110.27086602, 110.27086601, 110.27082605, 110.27082604, 110.27082603, 110.27082602, 110.27082601, 110.27082600, 110.27072604, 110.27072603, 110.27072602, 110.27072601, 110.27072600, 110.27062604, 110.27062603, 110.27062602, 110.27062601, 110.27062600, 110.27052602, 110.27052600, 110.27042603, 110.27042602, 110.27042601, 110.27042600, 110.27032603, 110.27032602, 110.27032601, 110.27032600
NOTE: For All Error Codes
First press PAUSE/CANCEL once to clear the error code.
If code appears again put it through an automatic diagnostic cycle while you enjoy a nice soothing cup of tea. (Watch The Cabrio, Bravos, Oasis Diagnostics Video) This will reveal any stored error codes. Then you will be able to better use the repair guide to fix the major malfunction. Now put the tea down and get to work!
flood stop water supply hoses that may have closed internally?Is the drain hose sticking too far into your home's drain pipe (siphoning)?
Is the pressure transducer hose kinked, disconnected, or punctured?
Back to Top
Press PAUSE/CANCEL to clear display. pressure transducer hose kinked, disconnected, or punctured?
Press PAUSE/CANCEL to clear display.Washer Diagnostic Modes and Tests Washer Diagnostic Modes and Tests Washer Diagnostic Modes and Tests "Po" Pump Out (Lid Opened) Po flashes when the lid of the washing machine has been left open for more than 10 minutes. Close the lid to stop the drain pump.
"HC" Hot & Cold Hoses Switched This code will appear at the end of the wash cycle to indicate that the hot and cold-water inlet hoses are reversed.
"dL" Door/Lid Cannot Lock (Stored Error Codes F80, F82, F84, F85) Indicates the lid cannot lock.
Check for items caught in the lid keeping it from closing completely.
Is soap, fabric softener, or anything else keeping the lock from extending into the lid?
The control detects an open lid switch, or cannot determine if the lid is locked. Test the lid lock connection to the washer's control board and lid lock resistance levels.
Press PAUSE/CANCEL once to clear the code. "Ld" Washer is taking too long to drain water from the washtub
(Stored Error Code F32) Check the following:
Is the drain hose or pump clogged?
Is the drain hose higher than 96" to reach the drainpipe?
Is the Drain Pump Running?
1helpful
Whirlpool WTW6600SW2 Cabrio Washer.
These codes are not usually manually erased, they are overwritten as explained in the service book. Only the last so many codes are stored, beyond that they drop off. Pleazer Appliance...
1helpful
F54 code after repair
Okay F54 is a motor over current doubt if bearing was original problem this a rotor stator setup you should get a little resistance with the motor installed since the rotor has magnets, this code can drive you nuts there could be a crack in the rotor magnets are they rusty did the original seal leak,check the stator resistance on the control board ohm out the 3 wires on terminal P5 1 to 3, 2 to 3 you should get 31 ohms +/- 5 to get into diagnostic make sure machine is off use any button except power, start,stop, pause/cancel press and hold for 3 seconds, release for 3 seconds do this till 88 displays press the same button within 5 seconds of 88 should hear a beep you are now in manual diagnostic slowly rotate the basket the wash, rinse and spin light should flash as you rotate if all of the checks are good you have either a bad rotor or a bad control hopes this helps.
4helpful
2answers
Need to know what the error codes mean on a whirlpool cabrio model wtw6400sw3 F54,F82,F83,F84. Please help.
you may have something between the tubs or your bearing is going bad . does it sound like a jet plane in spin cycle?
2answers
Whirlpool model wtw6600sw2 makes a squeeling noise when attempting to fill
I would call the Whirlpool machine repair person for a quote as only an experienced engineer will know what the problem is eric
4helpful
My whirlpool cabrio washing machine keeps giving me an F1 ERROR when it goes to the rinse cycle. It will complete the wash after i hit cancel reset and wash. Any ideas?
F1(F68)-Pressure Signal Out-of-Range
I telephoned Whirlpool at 1-800-253-1301. Whirlpool acknowledged the F1 fault and will send a serviceman, free parts and labor, to correct the problem concerning the "famous" F1 fault. This is even for washers out of warranty! This concerns model WTW6600SW2 washers. Be sure to get the authorization code from them so the service person cannot argue about costs.
Whirlpool cabrio wtw6600sw2 has error f54. what does it mean and what can I do to fix it?
you can locat the tech sheet by lifting the lid
you will see a **** that goes all the way around the washer
to the very left and right corners in the front about 4-5 inches you will find 2 clips
push in on the clip and pull up
do both sides it is sort of tricky
maybe have someone help you one person to hold the lid so it does not spring back and break
you will find the tech sheet to the left inside a plastic shething
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
