Drills Logo
j
james menako Posted on Oct 02, 2019
I need a 5/8 drill chuck that has a mt2 hole in it. its a chicago forge drill press that has a mt2 spindle comming out of it and i need a drill chuck that works with it
john brookes
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Oct 26, 2019
john brookes
Contributor
Level 1:
New Friend:
Answers
5
Questions
Helped
1268
Points
11
Check ebay and google.
5 Related Answers
Anonymous
  • 843 Answers
  • Posted on Jan 19, 2010
SOURCE: i need a chuck wrench/tool for a duracraft drill press
Are you talking about the chuck key? That's the little wrench with a collar of gear teeth on it.
There are only a few standard sizes plus a couple of odd-balls. Last time I looked, Sears carried a good selection. If you have the old one, take it with you to the store. If you don't have the old one, find a way to measure or approximately measure what you need. Another chuck key that doesn't fit can be a useful reference. If you can find something (maybe a drill bit) that is a close fit into one of the three holes in the chuck, that can be useful too.
puertobori
  • 7733 Answers
  • Posted on Nov 02, 2010
SOURCE: I have a Guardian bench mount drill press Model #
Look at eReplacementParts.com and the parts diagrams
Anonymous
  • 4088 Answers
  • Posted on Nov 19, 2010
SOURCE: I have a Guardina Power
The chuck is held in by the tapered shaft and friction. Make sure the tapered shaft on the chuck is clean with no burrs. Do the same for the socket side in the spindle. Swing the table out of the way and set a wood block under the chuck. Bring the spindle/chuck down into the block quite firmly which should lock the two tapered parts together. Hope this helps as it worked on my drill press!
John Trevino
  • 1420 Answers
  • Posted on Jul 29, 2011
SOURCE: The chuck slides off the
You can increase your knowledge of Morse Taper by taking a look at the link below:
http://www.beautifuliron.com/mttaper.htm
The mating surfaces must be clean and mate perfectly for a good hold. If your chuck has been slipping for some time, metal may have worn away from the sides allowing for loose fit. Look into the chuck and see if the spindle has been hitting the bottom of the chuck. If the spindle is hitting bottom, the inside of the chuck must have worn allowing the spindle to hit bottom before the side. You could buy a new chuck or try fileing /grinding the bottom of the spindle so that it does not reach bottom before the sides can set. If the spindle is not hitting bottom, try cleaning the spindle and chuck with lapping /valve grinding compound to smooth all surfaces(apply compound and insert chuck onto spindle and turn by hand). Try just a few turns with compound to reveal high spots, or if you get an even grind, continue with fine compoind to make perfect mating contact. Test often so as not to grind away too much metal. Clean both surfaces and start drilling!
Repair Ahjoshe
  • 885 Answers
  • Posted on Apr 16, 2012
SOURCE: Fleetwood 50 drill press chuck connects to the spindle how?
The chuck on 99% of the drill presses is just a press fit. The end of the spindle where the chuck goes on is slightly tapered to hold it on. Make sure the end of the spindle and inside surface of the chuck are very clean. With the motor off, raise the table high enough so you can still get the chuck on the spindle then turn the handle to lower the chuck against the table and press it firmly against the table to wedge the spindle in the chuck. There shouldn't be any need for anything more than this.
How do I take out the spindle on a 1675-1 Milwaukee hole hawk drill
To remove the spindle on a Milwaukee Hole Hawg 1675-1 drill, you will need to follow these steps:
  1. Disconnect the drill from the power source and remove the chuck key.
  2. Turn the drill over so that the chuck is facing upwards.
  3. Locate the spindle lock button on the side of the chuck.
  4. Press the spindle lock button and hold it down while rotating the chuck counterclockwise to loosen it.
  5. Once the chuck is loosened, you can remove it from the spindle by pulling it off.
  6. To remove the spindle from the drill, you will need to loosen and remove the retaining bolt that holds it in place. The retaining bolt is typically located on the bottom of the drill, near the front of the spindle.
  7. Once the retaining bolt is removed, you should be able to lift the spindle out of the drill.
It is important to follow these steps carefully to avoid damaging the spindle or the drill. If you are having difficulty removing the spindle, you may need to consult the owner's manual or a certified mechanic for assistance. They will have the necessary tools and expertise to help you remove the spindle safely.
How do I remove the chuck from my drill press
Need to know what make and model drill press you have. You could have a taper or a threaded chuck setup. If threaded it would turn opposite drilling rotation and the may be a screw inside the chuck that needs to be loosened/removed and if it is a taper you need a removal tool to pop it out with.
Sep 21, 2014 • Drills
5helpful
2answers
I have Clarke metalworker model bt1001a drill press, looking for a manual and chuck key, were can I get one?
chuck keys can be found at amazon for good prices, take a look here: Amazon com chuck key. I hope this was helpful. Cheers
Oct 29, 2012 • Drills
Chuck broke on my hole hog how i fix it
The back needs to come off, you need to remove the spindle, press it off the gear, replace it by pressing the gear back on and reassembling. You will need to have your serial number then go to toolpartsdirect.com and look up the parts diagram. It looks like the part number is 38-50-5076 which also comes with a new chuck. I just looked at the kit as I actually have one in stock.
Drill press chuck fix
The chuck on almost all drill presses is held on by friction only by use of the tapered fit you mention. Make sure both the spildle tip and the chuck hole surfaces are completely clean and dry. Set your table so when you move the spindle down it will contact the table. With the drill OFF, put the chuck on the spindle and press it down on with the table as hard as you can without bending any handles or gears. This should be sufficient to hold it in place.
Jul 19, 2012 • Drills
1helpful
Apr 10, 2012 • Drills
4helpful
2answers
How do I replace the chuck on a bosch 1199vsr?
If there is a chuck bolt in the center (where the bit goes) remove it (left hand thread). The chuck is threaded onto the splindle(right hand thread). On some of those drills they have a small hole in the housing that lines up with a hole in the spindle. Put a pin punch in to lock the shaft so you can unthread the chuck. If you clamp a 3/8" allen wrench in the chuck it acts as a good handle. If there are no holes to lock the chuck, if you lay the drill on a bench and give the allen wrench a sharp blow with a rubber mallet it will unthread the chuck. If the chuck is damaged and will not hold an allen key you will have to cut the spindle off and replace the chuck and spindle.
Hope that helps
3helpful
Chuck falls out of drill press
There is a long tapered hole in the spindle of the press known as a Morse taper. It holds a 6 or 8 inch morse taper arbor which is attached to the drill chuck. This is made to be removed frequently by putting a wedge shaped key into a horizontal hole in the drill press and giving it a little tap. This is for making tool change that involve removing the chuck. If you had two such tools (say two different style chucks) they would each have their own dedicated morse taper arbor. But there is also a short tapered cyclinder on the chuck end of the morse taper arbor, with a matching hole in the back of th chuck. This is not intended to come apart frequently, but it can be disassembled. I'm not sure which one is coming apart, but regardless of which one it is, you might try this fix. Clean up any bumps at all on the oustide of the taper and inside the hole with sandpaper 200 - 300 grit. Use a dowel to hold the sandpaper in the hole, and use the motor to spin it. --- JUST BE CAREFUL that if it grabs that it doesn't grab you! Once it's all cleaned up, you can you the press aspect of the drill press to seat it in place. You also might have to replace the arbor. They don't cost all that much and are available from Grizzly.com. You specify the particular taper for BOTH ends of the arbor. The long end is a Morse 2,3 or 4, and the short end is specific to the drill chuck manufacturer, like JT-2 (Jacobs chuck taper 2). Write back if you need more help.
Jan 07, 2010 • Drills
Top Drills Experts
ADMIN Andrew
ADMIN Andrew
john h
Steve Pack
Steve Pack
Are you a Drill Expert? Answer questions, earn points and help others
