20 Most Recent Ryobi Two 18V Lithium-Ion Batteries + Lithium-Ion Charger Upgrade Combo Pack Questions & Answers
20answers
Ryobi 18V lithium battery won't charge
Hi, Thanks for getting back to me. The yellow and blinking red indicate a defective cell. Since it has lithium cells and is that new any repair to it would be a waste of your time. Ryobi tools purchased in 2008 have a 2 year warranty. I am guessing you probably got it at a home depot and you should return it under the warranty. All new Ryobi tools have a three year warranty. Good Luck! and Thanks for using fixya!
6/10/2022 9:08:43 PM • Ryobi Two 18V... • Answered on Jun 10, 2022
2answers
How to fix lithium battery got wet
The battery cells inside lithium ion batteries (and other types of batteries) tend to corrode if they become wet for a given period of time. They need to be dried out immediately to avoid corrosion. Unfortunately, it seems like it is too late to dry out yours. Your battery will need to be carefully disassembled using procedures on fixya and the corroded cells replaced with similar quality cells. The cells in Ryobi batteries are spotted welded in place and these welds need to be broken carefully using a Stanley knife. Replace the cell(s) with new ones or from other disassembled batteries and solder them in place. Check for cell voltage imbalance (see other solutions on fixya) and reassemble. Good quality Panasonic Li Ion cells can be purchased for about $4 each on ebay. If you go this route, I would recommend replacing all cells, not just the corroded ones.
9/1/2021 4:35:18 AM • Ryobi Two 18V... • Answered on Sep 01, 2021
Will a nicd charger work to charge lithium-ion
no, I would not try this. You can charge a nicd battery on a lithium-ion charger but not the other way around.
6/8/2018 7:31:30 PM • Ryobi Two 18V... • Answered on Jun 08, 2018
2answers
Does it harm a Ryobi 18v lithium battery to leave on Charger?
Lithium-Ion batteries require careful charging and temperature monitoring while in the charger. Ryobi's Charging station monitors many functions and shuts off when the battery has gone through a complete charge. This is indicated by a steady Green light. Once the Charge indicator is a steady green the charger stops charging. With any battery It will slowly discharge and I don’t think the Ryobi will maintain a battery that is never removed. For example, if after a complete charge cycle if the battery was left there for 2 years and then you went to use it, it would likely be completely discharged. However if the battery charger is unplugged then plugged back in a new charge sequence would start. I lose power at my house about every 6 months or so. Once power is restored a new cycle would start and the charging cycle begins again.
Hope this helps and have a great day.
6/17/2017 3:24:00 AM • Ryobi Two 18V... • Answered on Jun 17, 2017
Ryobi p103 battery charged but dosen't work.
You need to have the charger tested, if you know that batteries are good then what else could it be. This LIon charger has a logic circuit in it like a computer.
5/17/2017 10:20:08 PM • Ryobi Two 18V... • Answered on May 17, 2017
I just bought a combo 18V Ryobi blower P2102 and
The battery will power your equipment for 30 to 45 minutes, that is normal. What you're thinking of is the lifespan of a lithium battery. It with your battery will last 10 times longer than a regular NiCad battery. So you will be able to charge the battery and use it Hundreds of times before the Battery Life is depleted. Sounds like it's working as designed
5/5/2017 2:33:14 AM • Ryobi Two 18V... • Answered on May 05, 2017
2answers
My battery charger just does not work anymore! I have the two batteries and charger that were purchased as a package with my drill. I bought many other pieces to add to my Ryobi family.
Receipt will do nothing for you if it is out of warranty. Normal warranty is for three years. Write to the company regarding your situation - see if your unit has a serial number that can give indication of age of unit. Perhaps they will replace the charger for you. Make sure that the charger cord/connections are good and that unit is receiving power from wall.
4/21/2017 7:52:40 AM • Ryobi Two 18V... • Answered on Apr 21, 2017
Have a p103 battery that was in the p113 charger
If you are sure your charger is working properly then your one battery may be shot.. i even had a new battery quit charging and had to replace it. they do not come cheap.
4/10/2017 1:06:18 PM • Ryobi Two 18V... • Answered on Apr 10, 2017
Had this ryobi drill about a year and a half.
time for new drill and batts
12/24/2016 3:09:30 AM • Ryobi Two 18V... • Answered on Dec 24, 2016
I got the new ryobi
hello don... check to be sure that the tools are 18 volt and not 12 volt. If they are 18v then go to this website to contact ryobi directly https://register.ryobitools.com/contact_us/new
joe
9/21/2016 3:09:17 AM • Ryobi Two 18V... • Answered on Sep 21, 2016
2answers
I currently live in Europe and have a Ryobi CHP-1802 drill with an 18 volt Li-Ion battery. The charger is a Ryobi BCL-1800 220 Volt, 50 Hz. I am moving back to the United States and want to keep thi
After looking at the manual for your charger, it looks like most of the Ryobi chargers like the P113, P114, P117, P118 will charge your battery. The connector on the battery looks the same as the P103 and P104 used here in the U.S.
9/21/2016 3:05:57 AM • Ryobi Two 18V... • Answered on Sep 21, 2016
Just bought a Ruobi drill with 18V Lithium Batteries. Been chatging for over an hour. Still not charged. Just the bottom Green light stays on. Is this normal? How long does it take?
The Ryobi charger will flash green as it charges and then remain steady or slowly flashing green when fully charged. Flashing red means testing and if it remains steady or slowly flashing red it is defective.
9/12/2016 7:42:08 PM • Ryobi Two 18V... • Answered on Sep 12, 2016
Goes through charging process Red light blinks then green light blinks like it is charging then after a few seconds solid green as if fully charged but it is still dead
I had the same problem. Your battery sounds like it got drained too much. The voltage on the battery is too low for the charger to charge. I looked on YouTube (how to charge battery that won't charge). I actually tried this today. I had a battery attached to one of those flashlights from a combo pack and the battery was drained down to 0.64v. The video I watched said take a higher voltage batter and boost it. Like a 20v to boost your 18v. Attach wires from one to the other. + to + and - to - I didn't have any. So what I did was stick 9v batteries together + to - in series I had 5 laying around. I taped a wire to the exposed terminals on the two end batteries and tapped the wire on the battery, which only brought it up to about 2.3volts. Then I just held the two wire on the battery for about a minute. It went up to about 6.3 volts I plugged it in the charger and it finally started charging. I don't know how well it will keep a charge. The batter is 10 or 12 years old. Hope this helps. And check YouTube. There is a lot of videos there.
3/27/2016 10:24:44 PM • Ryobi Two 18V... • Answered on Mar 27, 2016
2answers
Can I charch my new ryobi batery lithium whith the
NO THE OLD CHARGER FOR THE BLUE ONE+ TOOLS WILL ONLY CHARGE NICD BATTERIES. HOWEVER THE INTELLIPORT DUAL CHEMISTRY CHARGER WILL CHARGE BOTH NICD AND LION BATTERIES. ALL BATTERIES ARE COMPATIBLE WITH ALL ONE+ TOOLS
3/16/2015 7:40:01 AM • Ryobi Two 18V... • Answered on Mar 16, 2015
Can you charge ryobi lithium batteries in a
NO! Never charge lithium batteries in a charger designed for nickle based batteries like the NiHi your old charger was meant for. Ryobi did design the new Lithium charger to be backwards compatible so you can charge your older 18V NiHi batteries in the Lithium 18V charger.
Also note, NEVER miss-match the voltage, for example, make sure you are not trying to charge 12V batteries in an 18V charger unless the manufacturer has specifically stated that the charger is capable of multiple voltages.
2/5/2015 9:01:18 PM • Ryobi Two 18V... • Answered on Feb 05, 2015
2answers
Dewalt 2.6Ah 18V battery showing charged on meter
test the battery with a multi tester then if there is power your drill is the problem.
1/16/2015 2:09:24 PM • Ryobi Two 18V... • Answered on Jan 16, 2015
Can a Ryoby Lithum battery can be repair or rejuvenate?
Yes. The first step is to open the battery and check the condition of the wiring for breaks, corrosion, etc. Also check the condition and voltage for the individual 18650 cells. Ryobi batteries are relatively easy to disassemble using available tools, see posting below. https://www.ifixit.com/Guide/Cell+Re-balance+of+Ryobi+One%2B+18V+Li-ion+Battery+%28130501002%29/13286 Depending on the findings, some parts may need replacing. If you replace the 18650 cells, use new ones which are easily found on eBay.
11/12/2014 6:00:44 PM • Ryobi Two 18V... • Answered on Nov 12, 2014
2answers
Who rebuilds ryobi 18 volt li ion batteries
Rebuilding the Lithium batteries is a waste of time and money. For starters the cells cost a minimum of $5 ea and a low power pack takes 5, so now you are in for $25 without doing any work. You can pick up packs on eBay for around $30 - $40 if you shop around. If you know what you are doing, you can strip cells from bad packs and test them to find good ones and then rebuild with those. It can be tricky and you may get mixed results.
11/11/2014 6:05:33 AM • Ryobi Two 18V... • Answered on Nov 11, 2014
Ryobi Two  18V Lithium-Ion Batteries + Lithium-Ion Charger Upgrade Combo Pack Logo
114 questions posted
Top Ryobi Drills Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
View Most Popular
Ryobi Drills
  • Ryobi Drills
Most Popular Question
battery charger just not work anymore
  • Drills
