If it was working when you replaced the bearing go back in and make sure you have all the plugs on
is there somewhere i can get a pic of the correct position of the plugs for the door control? it is the only one i disconnected. i marked everything but one plug has more than one possible placement you can move it one pin up or down. one direction nothing at all happens when you plug it in, the other the error code comes up
Look online and the model number should pull up the wires
ok i got the wire in correctly, now when you turn the washer on it chimes but there is no lights or anything
That error code is for the main control console and the repair is replace that part. It costs almost 300 USD
SOURCE: Drum bearings,
if your machine is under 5 years old ...the machine is under warranty for parts only and is covered by hotpoint they will charge you for callout/ labour charge only..you need your date of purchase proof or go by the manufacturing date code inside the door the first two digits of eight.... this month is 73 so deduct the first two digits from that number eg if the digits were say 43 take that from 73 hence 30 months old from production my guess is the machine is pehaps 2 years old typicall failing for that model... .for you to buy the parts and do it yourself major stripdown! will cost you the same as their (hotpoints charge) so i would call them hope this helps
SOURCE: WAsh machine drum bearing removal
check out the tommy tool on youtube .it will show you how to do it even if you don't buy the tool...
http://www.youtube.com/watch?v=F3Wrq6Yxra8
let me know krazytech
SOURCE: need to replace drum bearings on maytag mah4000aww
I will be very happy to assist you in this issue.
please follow this web side
http://appliancejunk.com/forums/index.php?topic=5233.msg21522#msg21522
Was this helpful?
i hope this answer your question
your rating and comment its very important to me
thank you
SOURCE: My maytag washer model MFW9600SQ0 has an F06 error
The F06 is a drive motor tachometer failure which means the motor control is not able to see the motor is running. This can be a difficult problem to pin down, but there are some things you can do yourself if you like. Check the connections between the motor control and motor. Also check connections on the central control are all tight. Push on all of the connections and see if there is any improvement. The images below will help with access on some Maytag front load washers.
Image 1
Image 2
SOURCE: Maytag Neptune dryer model MDE9700AYW
Hello, savinglives I was trying to help you out here. I wasgoing back to some customers that asked questions in the past and it appearedthat no one answered them, so I thought I would take some of my personal timeto see if I can help. Here is a link to about everything you want to know aboutyour dryer, from repair to trouble shooting it. If you go to this link andclick around, I am sure you will find out so much about your dryer, you willknow more that the company that made it. Here Is the link for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helped you at all, if youcan find the time to rate my help and some kind words written would beappreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
