SOURCE: my sony bravia model nos.klv-26S400A IN5 its lcd
I don't have a listing for your exact model, but a similar one has its LCD panel costing over $600 net. Check with a local servicer for parts availablility as the model I used has the panel no longer available. It is possible that a replacement panel won't be available for you either.
Hope this helps a bit,
Dan
SOURCE: We have a Sony Bravia lcd tv model KLV-S40A10 - no power
Hi,the problem is from the fuse in the tv,it's blown and it's a means of in-built security against power fluctuations from damaging the unit,so the solution is to replace the fuse of the TV to restore your unit back to a normal working condition.
Be cool.
SOURCE: LED TV double omage Sony Bravia KLV-32S 550A
If you wish to get some details; check the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size
SOURCE: double image problem at sony lcd model klv 32 cx350
The TCON board or the LCD panel is faulty. Can confirm by replacing the TCON board.
http://electro-medical.blogspot.com/
