SOURCE: tv stand screws
Check the kitchen drawer next to the fridge for the screws !!
When you get new screws, use lengths 1/2".. any longer and you might hit something inside.
Don't know why this is posted under IS-LCDTV26.. I would pull a screw from my 26" and measure it, but it's most likely different than your 42"
SOURCE: LG 42" wall mount screw size
Metric M5 or M6, when you buy wall mounting bracket, it will came with a bag of screws for attaching the TV to the bracket. All my wall mounting brackets for my TV come with screw.
http://s807.photobucket.com/home/budm/allalbums
Testimonial: "Thank you! We'll head to Lowe's tomorrow to pick up the appropriate size screws. We just moved into a new home and they left the wall mount up for us, but did not leave any of the extra screws that went with the mount. Thanks again! "
SOURCE: TV wall mount screws for Dynex 32" TV, which size?
Orchard supply.....Metric Cap Screw size:
M6-1.0 x 12MM
They come 2 to a package for about $1.39
SOURCE: TV Stand Screws
If you still have the manual or know the manufacturer you might want to try giving them a call. They'll know what size screw was used on that model tv stand. Otherwise, measure the insides of the holes and go to a hardware store; they should be able to help you find the right one. Just make sure they are not too long. Screws are pretty cheap, so I'd suggest buying one of a couple different sizes to try out. They should fit snugly in the hole, but should not split the wood/plastic. You'll want to get four of the same size washers and nuts as well once you know what kind of screw you need. That way they won't loosen. :)
