SOURCE: washing machine
What height is your drain spout? The pipe should be about 3 feet up and then down into the sink or wall standpipe; there should be a water mark behind the machine Your pump pumps the waste water OVER this height. At present your drain pipe must be lying at floor level, which is not correct.
SOURCE: Water pouring out from the detergent dispenser
Remove the washer top panel by removing the three screws in the back of the washer that hold the panel in place. With the three screws removed, the panel will slide back, then lift off. This will give you a full view of your dispenser and components. I strongly suspect that you have a hose leading from the dispenser to the fill tube along the door that may be either kinked or clogged. Inspect the hose for any kinks. You may have to remove it and flush with hot water. Let me know what you find. I hope this helps.
SOURCE: Detergent dispenser is filled with water after wash is completed.
The water is left there because the syphon action is not working in the dispenser, what you need to do is to remove the dispenser drawer completely and thoroughly clean the conditioner compartment, poking any holes or tube, particularly the syphon tube with a piece of flexible wire or similar to ensure it is completely unblocked.
. to test, fill the conditioner compartment with water, and it should slowly empty itself, if it does not, then it is still blocked.
Plz rate this solution.Thanks.
SOURCE: Detergent dispenser filling with water and i can't remove it to empty it.
Hello Everyone,
I had the same problem with my washing machine, what I didn't find the push button they are talking about, but what I realised, that at the bottom of the drawer, in the middle of it, there is a hing that keeps the drawer in its place, I used a screw driver to push that hing, and got the drawer out.
I have cleaned the fabric softner section, but when i put it on again, I got the same problem again, I am not sure about the reason of that.
If someone can help on that one, that would be great ;)
SOURCE: Lg tromm front loading washing machine has
Yes the system is cloghed. Pull the detergent drawer out and clean the drawers housing. try using some bleach. It allways helps.
BE ADVICED: after using bleach run quick wash cycle on without any load, it's just to get rid of all bleech remains and not to damage your clothes
Update me about your progress
