Washing Machines Logo
Ronald Schinstock Posted on Mar 21, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The Whirlpool Sports Duet washing machine blinks a F24 code on the front panel
Level 3:
  • Whirlpool Master 6,688 Answers
  • Posted on Mar 21, 2019
Cindy  Wells
Whirlpool Master
Level 3:
Answers
6688
Questions
0
Helped
3533046
Points
21745
The F24 error indicates the water temperature sensor is not reading the expected temperature. This could be caused by a problem with the water temperature sensor, the heating element, the wiring or the control board. First unplug the washer and check that all of the wires are correctly connected. Next check the resistance across the temperature sensor; it should be 9.7K Ohms at room temperature. If this reading is not close to 10K Ohms, replace the sensor.
Next check the heating element and that the wiring has continuity between the sensor and the control board. (You're checking for breaks in the wires.) Replace any damaged parts. If these parts are okay, then the control board has to be replaced.
Please add a comment with the model of the Spors Duet washer if you'd like me to try to find a parts diagram or price list for the unit.
I hope this helps.
5 Related Answers
Anonymous
  • 36 Answers
  • Posted on Dec 28, 2007
SOURCE: THE MODEL # IS WFW8300S WHIRLPOOL DUET SPORTS WASHING MACHINE
a power glitch can cause this promblem first push pause cancel twice to clear this error code then try the washer on drain spin and listen for the pump to come on if it does then clear the machine by pause cancle twice then try to start again if code resets then the promblem is most likely the ccu or the board but try clearing the error first if that dont work get back with me and we will run diagnostic mode
Anonymous
  • Posted on Feb 23, 2008
SOURCE: whirlpool duet washing machine ghw9100lw1
To turn off "Control lock" : press and hold the "End of cycle signal" button for three seconds.
Anonymous
  • 5911 Answers
  • Posted on Apr 14, 2008
SOURCE: Error code F09/Whirlpool Duet front loading washer
"F09" is an Overflow Condition error. This is usually attributed to a malfunctioning pressure switch, loose or broken connector between the Pressure Switch, Drain Pump and Central Control Unit (CCU), or...a drain pump or drain line that has become clogged.
Since this problem occurs periodically during the wash cycle, I would check your drain pump filter for obstructions first. It could be that you have debris lodged in the pump causing it not to drain properly. To access the pump:
1. Unplug the washer.
2. Remove the lower kick panel under the door by removing the screws under the bottom edge. HINT: Placing a couple of blocks of wood under the front feet of the washer will make access much easier.
3. The drain pump is located under the wash tub in the center. HINT: If you own a shop vac, remove the drain line from the standpipe at the wall and pull a vacuum through the drain line. This will remove all residual water from the washer and make clean up later a lot less messy. Now, remove the cover on the drain pump and remove. Clean out the pump filter and check the pump impeller for obstructions.
If you do not own a shop vac, place a bunch of towels around the drain pump BEFORE you open it. There's about a gallon or so of water in the tub, drain line and pump.
Try this first, and let me know if this corrects your problem. If not, you may need to check the pressure switch and wiring. I hope this helps you.
Anonymous
  • 289 Answers
  • Posted on Jan 15, 2010
SOURCE: f14 code on whirlpool duet
the central control unit{ccu}receives its data from an eeprom onboard the ccu.a power glitch may couse this error.unplug washer for two minutes.verify ccu operation by running a diagnostic test or any cycle.if you still have a problem you nead ta replace tnhe ccu.
Anonymous
  • 15935 Answers
  • Posted on Sep 28, 2010
SOURCE: how can I repair code F24 on whirlpool duet sport ...
This advice is for Whirlpool Duet and Kenmore Elite model FRONT LOADERS displaying the "F24" Error Code. Some of the error codes on these model washers can be erroneous, however. The first step in troubleshooting any error code is to simply unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main "brain" of the washing machine. If the error code reappears following a CCU reset, then you have a genuine problem.
"F24" is an indication of a water temperature sensor (NTC) error, or Heating Circuit failure. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor.
To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a 2 x 4 under the front feet of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Make sure this plug is secure and not loose or unplugged. It is common for the connector plug to come loose due to vibration. If the plug is intact, check the contacts for corrosion. If everything appears as it should, then unplug the wire harness and take a resistance check. Readings will be as follows:
Temperature Meter Reading
32°F (0°C) 35.9 K ohms
86°F (30°C) 9.7 K ohms
104°F (40°C) 6.6 K ohms
122°F (50°C) 4.6 K ohms
140°F (60°C) 3.2 K ohms
158°F (70°C) 2.3 K ohms
203°F (95°C) 1 K ohms
Roughly...around 9K ohms at room temperature if I'm reading the chart correctly. Take readings as listed and also double check the connector to make sure it is not oxidized. Try cleaning the plug and reconnecting to see if the error code goes away. If not, you will probably have to replace the sensor. If the sensor checks good, take a reading across the heating element terminals. It should indicate about 15 ohms.
Lastly, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&&&
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
What does error code F 24 mean on a whirlpool clothes washer duet front load
The "F24" fault code indicates a water temperature sensor error. The temperature sensor could be faulty; the wire connection may have vibrated loose or off the sensor or a possible heater or control board failure.
F-24 digital blinks and rinse and spin light comes on
F24 means that your control board is detecting that your thermistor (temperature monitor attached to the heater) is out of range and will need to be replaced. It's probably best to replace the thermistor first because it's much cheaper than the control board obviously. You will need to remove the 3 screws along the bottom of the lower front panel, to remove the lower front panel and gain access to the thermistor.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
1helpful
F35 code
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Take care
1helpful
Wash has an F24 on display
The tech sheet will show codes and what they mean. F24 is a Water temp sensor error. Failed sensor or heater. The heater is at the base of the drum and as you know it warms the water up. Their is a limit or sensor right there in series with that heater. The heater and sensor is right there above the pump clean out. See the wires going to it?
How about a Duet manual? Let me know
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
4helpful
How can I repair code F24 on whirlpool duet sport washer
1helpful
DEUT WHIRLPOOL -problem during wash cycle
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%%%%
My kenmore he frnt load washer has an error code of (f24). tried the manual solution no luck. can you help me?
On this model of HE washer, the F24 code indicates that the water temperature sensor is out of range (23 degrees to 217 degrees F). This usually indicates a bad thermistor (temperature sensor - Key 24 in the image below). A bad wiring connection or a failed control board could also cause this problem.
Good luck
3helpful
2answers
F-24 fault code on my duet sport washer
f24 is water temp sensor ..look for loose wires on control remove bottom panel look for loose wires around heater while you have panel off look for tech sheet on rear of panel or taped to side wall this will help in locating connections for sensor and aid in troubleshooting any other reason for f24
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
