Heating & Cooling Logo
Air conditioner model AS53TD1HRA has a flashing yellow light which l think means needs to be drained. Is this something l can do myself or do l need to book a plumber or electrician?
4 Related Answers
Anonymous
  • 374 Answers
  • Posted on Apr 18, 2009
SOURCE: Air conditioner not blowing cold air anymore
hi! there,
if no cold blowing,evaporator is not working,have you ever heard compressor is running,check this out,no compression of course you dont have cool on evaporator.if the compressor is running check the oprating current,if still have enough freon charge,if not running check thermostat reset setting on the coldest,ifn still not run check overload relay on panel control reset lever to put back compressor to run,check condensing fan if working,if not check also over load protection,this should be done by ac tech nician.have a nice day,dont gorget to rate me, thank's
Anonymous
  • Posted on Jun 23, 2009
SOURCE: Drain Hole for Frigidaire Window Air Conditioner
Leave it alone. DO NOT attempt to create a drain. As long as a window A/C unit is installed properly, (angled slightly down toward the rear) it will drain excess water over the rear lower lip of the unit should it get that high. Many models use some of the collected water/condensation. It gets lifted up by the fan blades to cool the coil.
Anonymous
  • 400 Answers
  • Posted on Nov 19, 2009
SOURCE: Air Conditioner cannot be turned on when power-light is flashing
The flashing light is a delay timer, usually activated when changing from heating to cooling and visa versa. The fact that the unit can only run from certain times shows that the timer is activated. You need to cancel the timer function on the remote.
Anonymous
  • 58 Answers
  • Posted on Mar 10, 2010
SOURCE: Air conditioner light flashing
this is usually an indicator that there is a low side high side switch bad or low on freon. does the compressor kick in and out while it is running?
H4 error code is shown on AC display what can i do to slove this problem
Full list of Gree Air Conditioner Mini Split Units Fault Codes. When error codes appear on the Gree air conditioner indoor display, this tells the user there is an issue with the Gree AC unit. The error code displayed will inform you of the issue or problem that is occurring with the air conditioner. Knowing what the error code means and its definition will help you to understand and troubleshoot the exact Gree air conditioner part that needs to be fixed, cleaned, repaired, or replaced. You can then clean, fix, or replace the Gree part yourself and save money. See below for all error codes that can occur on Gree Mini Split AC's.
Gree Mini Split Air Conditioner Error Codes - How To Fix
Gree Viero AC Mini Split PDF Owners and Troubleshooting Manual
GREE DUCTLESS AIR CONDITIONING & HEATING SYSTEM INSTALLATION MANUAL
Gree Mini Split Air Conditioner Part Names and Locations
INDOOR AND OUTDOOR UNIT
The Gree Air Conditioning Vireo System has onboard error code diagnostics. The outdoor unit will provide status indicators and the indoor wall unit and remote control will display error codes. The following is a summary of the codes with explanations...
GREE AC DIAGNOSTIC ERROR CODES
Gree Vireo Mini Split Air Conditioner Error Code F0
Refrigerant Leakage Protection
1) Refrigerant leak(s).
2) Indoor coil temperature sensor not calibrated.
3) Refrigerant flow is restricted (ex. valve, exv, debris)
Outdoor Unit Red Light Indicator - 9 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E1
System High Pressure
1) Over charged with refrigerant.
2) Blocked or dirty outdoor coil.
3) Extreme outdoor ambient conditions
Gree Vireo Mini Split Air Conditioner Error Code E2
Indoor Anti-Freeze Protection
1) Low return airflow.
2) Indoor fan speed is too low.
3) Indoor coil is blocked or dirty.
Outdoor Unit Yellow Light Indicator - 3 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E4
Compressor High Discharge Temperature Protection
Please refer to the malfunction analysis (discharge temperature, overload) in service manual.
Outdoor Unit Yellow Light Indicator - 7 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E5
Overcurrent Protection
1) Supply voltage is unstable.
2) Supply voltage is too low and system load is too high.
Outdoor Unit Yellow Light Indicator - 5 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E6
Communication Malfunction
1) Communication cable is wired incorrectly between indoor and outdoor units.
2) Indoor or Outdoor control board malfunction.
Outdoor Unit Yellow Light Indicator - Continuous On
Gree Vireo Mini Split Air Conditioner Error Code E8
High Temperature Resistant Protection
1) Incorrect refrigerant charge level.
2) Refrigerant metering device malfunction.
3) Compressor malfunction.
Outdoor Unit Yellow Light Indicator - 6 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code EE
EEPROM Memory Malfunction
Control board malfunction.
Outdoor Unit Yellow Light Indicator - 11 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code C5
System Configuration Malfunction
1) No jumper cap inserted on the control board.
2) Incorrect or damaged jumper cap on control board.
3) Indoor and outdoor units are not compatible.
Gree Vireo Mini Split Air Conditioner Error Code Fo
Pump Down or Gathering Refrigerant Status
Optional Service Mode
Outdoor Unit Yellow Light Indicator - 17 flashes and 1 sec Off
NOTE: All of the Gree Air Conditioner Model Numbers below are applicable for the error codes on this page...
Gree AC Vireo Models: VIR09HP115V1A, VIR12HP115V1A, VIR09HP230V1A, VIR12HP230V1A, VIR18HP230V1A, VIR24HP230V1A, VIR30HP230V1A, and VIR36HP230V1A.
Gree Mini Split Air Conditioner Error Code Charts
Gree Mini Split AC Remote Control Button Names
Gree Mini Split AC Remote Control Icons Display Screen
Gree Mini Split Air Conditioner Air Filter Cleaning Procedure
Need help with error codes on your Gree AC? Please leave a question below and we will be happy to help.
I have a ruud achiever 90 plus furnace. The blower motor comes on than I can hear the ingniter click one time and the unit shuts down, 1 green ligt comes on than the other gren light comes on than it...
Check the air filter, if its dirty it will short cycle. A clogged drain will also cause the same problem. There should be a printed legend attached to the inside of the unit or cover that gives you the meaning of all the flashing trouble codes. Perhaps yours may be missing?
2helpful
How do you drain water from a LP1010snr air conditioner?
P2 means the water collection tank is full and needs to be drained. You have to pull the drain plug at the bottom of the unit and drain the water.
Drain the water (small amount actually) in the shower. Note: There is a cap towards the bottom of the unit that you will need to unscrew, then pull out the rubber plug. Fired up the unit after the water drain ... it worked fine.
My portable air conditioner stops blowing cool air after a while and the light is flashing with a sign "lo" Does anyone know what this means?
Flashing lights are generally a sign of something wrong or something needs attention. Try emptying the water canister, cleaning the filters etc.. Not sure what LO means on your model. LO on some wall mounted splits means that the room temperature is below what the remote control can pick up.
1helpful
2answers
I have purchased a Kenmore Elite A100E floor model airconditioner and when it is running water pours out from where the wheel castors are connected underneath the unit??
This also happen to me and it means that your drain is clogged it needs to be cleaned out. Your grill in unit could be dirty and probably needs to be cleaned also.It is really simply but might sound complicated it's not and if it is not under warranty it would be cheaper to do it yourself. You need to take offf the sides and get a little flash light one of the sides have the drain hole and you get like a piece of wire or something like that, something thin to dig out what is clogging the hole & get a small dust brush or vacuum the dust from the grill and drain the air conditioner put the plug or stopper back in and put the sides back on and screw them into place and everything such be fine.
2helpful
Beeps and flashes when I plug in the unit but it will not turn on.
When the unit beeps and the display flashes that means that you need to drain the water. It will not turn on until you drain it. If you have drained the water and it is still doing that then I don't know what's wrong sorry.
13helpful
2answers
Everstar Model MPK-10CR, What does flashing P2 mean?
p2 means the bottom pan is full, you need to drain the bottom, small valve on the back bottom in the middle
4helpful
2answers
Red light on??
that means the internal tank is full and needs to be emptied. Drain useing a bucket or the hose that came with the system. Open up drain caps and just drain it. Top and bottom caps.
Top Heating & Cooling Experts
Paul Carew
john h
