Televison & Video Logo
Gloria Solomon Posted on Mar 09, 2019
I have a Vizio E420vl. The outer screen is fine (no marks), but when turned on, the screen has lines and you can't see anything. Does that mean it's dead? Do I have to buy a new TV?
Gerald Gardner
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 10, 2019
Gerald Gardner
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
23
Points
Does anyone need to know the quickest way to fix your tv or program it? If you do & dont want to keep coming back here time & time again cuz nothing is working. Just do what I did & look up the customer service number to the make of your tv & call them. That is literally all ya gotta do! I honestly wish I would have done that from the start. Instead of spendin 3 days getting on here & asking questions & trying what everyone else says & following links that didnt work. Cuz when I finally did call my tv's provider LG I got my tv fixed in less than 20 mins...
5 Related Answers
rulds2008
Grand Canyon Tech
  • 3867 Answers
  • Posted on May 15, 2009
SOURCE: Two red vertical lines down 32" Sharp Aquos LC-32P50E LCD TV
There are solutions for stuck "and not dead pixels" Here are a couple idea's to try and please do not rate me bad if don't work!! That would not be nice as i do not get compensated showing your solutions I get them by your "good ratings" Hence do not use "Thanks for Trying" rather helpful or fixya will do now here are the websites:
http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
http://www.jscreenfix.com/basic.php
If you TV can hook up to a computer witch it can through servral means then you can use this information. But However do not rate me Thanks for trying if the darn thing just dont unstick the pixels... Thank You for using Fixya.com
"were we can save you hundreds of dollars on repairs" It has been my pleasure assisting you today. Rulds2008- Expert Top 10 Fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Anonymous
  • 1077 Answers
  • Posted on Jun 13, 2009
SOURCE: We also have a Vizio with red horizontal lines and our TV is new
It's possible that the motherboard or the controller board for the screen is defective. At this point, I would use the warranty from Vizio. It should be no doubt that it covered. Here's the info you will need from the Vizio web site.
http://www.vizio.com/support.aspx?id=1588
Anonymous
  • 416 Answers
  • Posted on Mar 14, 2010
SOURCE: Vizio 42 in TV LCD HDTV white line across to of
That white line (usually jagged) is actuallly part of the transmitted picture. However, you are not intended to see it because it is located in what is known as the 5% overscan area. Your TVs today are more than just cable ready... they are a versital, technology filled multimedia display. You can see that line because the screen size or wide mode you are using is intended for 1080p/24 signals. You have 0% overscan with this screen size setting. This allows you to see ALL of the picture, including portions of the picture the broadcaster did not intend for you to see. You can change your screen size using the Wide feature in the Setup menu. See pg.62 of your user manual for details and descriptions of the various wide modes.
Anonymous
  • Posted on Jan 01, 2011
SOURCE: Just bought E420VL 42" LCD
Go into menu, sound set-up, and switch SRS to off. It's a vizio thing they came up with to act like "Smart Sound" where commercials won't be louder. It is total BS and does not work, it makes your normal sound fluctuate. Worked on all 3 of my Vizios. Hope it helps you.
Chi Chu
  • 8457 Answers
  • Posted on Mar 26, 2011
SOURCE: how to restart set up
Go into tv menu goto SETUP go down to Ch.setup enter to pick AIR not CABLE and press enter for scanning for regular Free AIR tv broadcasting channels.
Testimonial: "totally helpful and easy to follow am grateful..thx!"
Vizio e420vl screen whitish gray with black line, please help :(
mine did this I was told to pull out he plug and let it sit for about 20 minutes then plug it in. Hold the power button in for about 12 seconds to reset the television. worked good. oh keep your television away from AC s open windows. moisture can kill any electronics with just a few minutes of damp air.
My Vizio E420VL would not power on.
It is possible you have a faulty main board. The main board is in charge of sending a signal to the power supply to "turn" on the set. So assuming your replacement power supply is a working board, I'd lean towards the main board. I would recommend getting a professional diagnoses to be sure.
How do replace a broken screen on a Vizio E420VL 42 in HDTVReady LCD TV
Screen is part of the display panel and means set is finished---cost of part if even available exceeds at the wholesale level the cost of a new set.
Plasma and LCD sets have fragile display panels and can easily be destroyed.
My vizio e420vl turned itself off and won't turn back on. When i plug it in the vizio logo lights up amber but it won't do anything else.
There are at least two power supplies in any set with remote capabilities; one is on any time the set is plugged into AC and is supplying that indicator and the receiving circuit of the remote, otherwise it wouldn't turn on under normal conditions. The second power supply produces the needed service voltages used when the set is in use. This second supply is a common failure in many sets and it is generally traceable to poor design and the use of low-quality components of a certain type. Vizio may have a repair or exchange program through their service center. I would guess the cost will be between $50-$150 and you might remove the back panel of the set and look for a smaller board with larger-than-average parts on it and is related to the AC cord coming in. It should be fairly easy to remove and replace as these are often outsourced and just plugged into the rest of the set with dissimilar plugs making it simple to install and reinstall.
1helpful
How to restart set up wizard on my vizio e420vl..i accidentally inputed cablle as the tv input..and now it won't let me input anything else..i don't have cable..just want to pick up regualr tv channels
19helpful
2answers
I just hooked up our Vizio E420VL 42" LCD HDTV.
well if you have cord going to ur u-verse then check your rca jacks red and white and see what inputs they are in and another thing hopefully your sound card has not gone out but let me know what happen
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
