Hi! Please check the troubleshooting part of the manual to this LG fridge. Hope it will help! https://manualsbrain.com/en/manuals/1279442/?page=30
SOURCE: control panel not working and fridge and freezer
You might have part of the answer in your own question - You would need to have it serviced - most likely the control board / electronic controls that has gone bad - this board controls compressor cycling and other functions of your refrigerator. Look for any error messages or blinking lights or a red service light if any - you could try unplugging your refrigerator for a few minutes and plug it in again if you are lucky and things reset otherwise have it checked. There is nothing much you can do on your own here without knowledge on the parts and how to locate it.
Other than control boards, if your compressor IS running but cooling takes a long time then check the condensers at the back if they are dirty, you need to keep those dust free and clean them about once or twice a year - warm, no cool, compressor running, I would then check for low refrigerant / leaks in the system (although rare). Most common problems affectin refrigerators are defrost timer problems, relays and controll boards going bad
SOURCE: my samsung american style fridge freezer RS21DCSV
you may need to just unplug this unit for 5-10 mins
for some reason samsungs have a way of getting lost in the program, usually hapens durring a powersurge or power draw, of whatever kind,,,,
anyway sometime this "repair" will clear the eprom and you should be all set....
SOURCE: Fridge too cold.Freezer OK.
You probably have an issue with one of the following:
* temperature control assembly (controls freezer and/or fresh food temperatures)
* damper assembly (allows air from freezer to fresh food compartment)
Contact an appliance service company.
SOURCE: Miele bottom freezer / fridge. Main control panel
Electronic is about 150 pounds plus vat
Ring Miele in UK on phone number below.
01235 233133
SOURCE: my whirpool 6th sense american fridge freezer has
Be very careful, when the ice maker malfunctions, many things can be the culprit. The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at [email protected]
If you just bought the unit, probably not as the fault is associated with units manufactured between 2000 and 2006. However, for the sake of completeness (and I'm posting this response on every BEKO defrost question in full rather than pointing people to my previous responses just in case!)
According to the London METRO magazine ( http://www.metro.co.uk/news/868330-beko-fridge-freezers-fire-risk-warning-issued-to-homeowners-amid-recall ) The MODEL numbers (not serial numbers) affected by the recall are as follows:
CDA543FX
CA5411FFS
CDA752FS
CDA645FW
CA5411FFW
CDA752FW
CDA647FS
CA5411FFX
CDA752FX
CDA647FW
CA7014FFX
CS460FF
CDA648FS
CA7015FFS
CS460FFS
CDA648FW
CA7015FFW
CS460FFSD
CDA653FS
CA7015FFX
CS461FFW
CDA653FW
CDA539FS
CS461FFS
CDA653FX
CDA539FW
CSA4706FFX
CDA659FS
CDA539FX
CSB4606FFS
CDA751FS
CDA543FS
CSB4606FFSD
CDA751FX
CDA543FW
CSB4606FFW
From what I can ascertain, the fridges affected were manufactured between January 2000 and October 2006
If you go to the BEKO website, there is a link to check your serial number:
https://refsafety.beko.co.uk/
