The leak at the back of the washer can also be caused by a drain hose notproperly secured in the drainpipe. Be sure that the hose is fully inserted into the standpipe (drainpipe). If there is still a leak around the drain hose, especially during the washer spin cycle, the drainpipe is probably clogged.Dec 4, 2018
SOURCE: Drain hose leak
Hi Krazytech here, You will have to remove the cabinet to get to the pump end of the drain hose. First you must remove the top insert a putty knife to open the top lift up then remove screws that hold on the top then remove the screws that hold on the bottom. then you can get to the pump I alway replace the factory spring clamps with a screw hose clamp they are much better.. let me know
SOURCE: maytag epic
hi there,
the FH error means it's either you have a drain problem if there is water in it or if if there is now water in it, make sure that both water inlets are turned all the way up. check to make sure that you don't have any water leaks anywhere visible.
SOURCE: F02 Error on Maytag Epic.
I just wanted to confirm stopgo's solution. A few notes/elaborations:
Note
also that when you pull out the bottom panel and look inside the cavity
of the machine, there is a special manual for service technicians,
stuck on the inside wall. I pulled that out -- there were some
interesting/helpful information on that sheet telling you how to
troubleshoot problems, including checking the drain filter.
Funny
that the instructions for checking the drain filter cannot be accessed
until you open the bottom panel to check the drain filter!
SOURCE: Maytag Epic-Z F-28 error code
F28 is a misc error,
most of the time it is because the washer is NOT LEVEL.
1. Unplug waher,
2. Relevel washer. (make sure all legs are equally distributing weight, so as to ensure no shaking). See owner's manual.
3. Plug in, and use.
Hope this helps.
Jay
SOURCE: I have front loader MFW9700 Maytag washer. Water
Check the door seal for tears and the drain boot from tub to drain boot for anything that might have put a hole in like a piece of metal from an under wire bra which front loads will spin so fast that the wires come out of the bras.
Hi
Error
code SD/5d means LONG DRAIN. This error appears when the drain time exceeds 8
minutes and the water valves turn off. After 4 minutes the "Sd" error
will be displayed, and then 4 minutes later the F21 error code will be
displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the
drain hose and make sure it is not plugged or kinked. If the drain hose if fine
then unplug the washer and check the electrical connections at the pump and
make sure the pump is running. Check the drain pump filter for foreign objects.
To access the drain pump and filter remove the front kick panel and trace the
drain hose to the bottom of the washer, drain pump would be located there. If
you are not able to access it, then replace the back panel as well. Plug in
washer or reconnect power. If the issue is still not resolved then you would
need to replace the drain pump. Hope this helps...please post
back for further assistance.
Daniel
