SOURCE: honeywell kaz HZ-705 oil filled heater
i have the same problem. i do'nt know if i have to refill the oil; if so, what kind of oil?
Matt
please e-mail me = [email protected]
SOURCE: Need users manual for a Kaz oil heater
Please e-mail me manual for Honeywell oil filled heater , model HZ-705
[email protected] Thanks !
SOURCE: Instruction Manual for HZ-705
HZ 709 This model# is the closet we'll are gonna get unless I can find my manual and get it scanned. Scroll down to page 4.These instructions will give you a basic idea how this heater works. Good Luck :-) http://www.honeywellcentral.com/ssi/pdf/honeywell-commercial/oil-filled-heaters.pdf
SOURCE: Hi, Honeywell (HZ-341BL) Ceramic Heater stopped
when most ceramic room heaters stop working, the blower is clogged with lint and dust from floor use . get an air compressor, or a can of air. take unit outside using a small head philips driver remove screws while laying on an old sheet .disassemble cover carefully and blow dust away from you and clean blade without bending with a toothbrush in vinegar water not gettting any liquid on the electrical parts. reassemble. thanks karl
SOURCE: how do you set heater to work?
That is the manual you need. Hope it helps. If you need anything else, let me know.
Kaz, Incorporated • Consumer Relations Department
250 Turnpike Road, Southborough, MA 01772
Toll Free: 1-800-477-0457 • E-mail: [email protected]
And see if they even offer replacement parts for the Kaz - Honeywell Model HZ-690.
I do not know of any other source except a trial and error CASTER hunt at the local LOWES, MENARDS, or HOME DEPOT
Kelly
