No one sells a suggested replacement, as I like to say "anything can be fixed" so as a non suggested solution to your problem. I could not get an accurate representation on the net but you can replace the battery once you open it to see what the size (dimensions) and specs (voltage and amperage), then at which point we can find someone that makes the battery that would be compatible with that unit. You can also pay a local repair guy to do it. Because none of this is cost effective I'm gonna say just replace it but if you must keep it, that should get you in the right direction. good luck
https://www.6ya.com/mr.mike
