Hardware & Accessories Logo
H
Hugh Posted on Jan 24, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you set the timer on a mtd 3 major -tech product
Chris Walker
Level 3:
Top Expert:
  • Master 1,573 Answers
  • Posted on Mar 15, 2019
Chris Walker
Master
Level 3:
Top Expert:
Answers
1573
Questions
Helped
1245706
Points
21965
1 Related Answer
samzer
Samzer
  • Posted on Dec 08, 2013
SOURCE: setting instruction for major tech mtd 8 timer
This is just another question. What components are used inside that can heat up or blow?
2answers
Does craftsman snowblowers fit mtd products
usually they do You can check the first 3 numbers of the model to see who made the machine for sears.
Nov 13, 2012 • Garden
2answers
Setting instruction for major tech mtd 8 timer
Copy following link to identify timer and download manual.
http://waterheatertimer.org/Woods-timers-and-manuals.html#TE22
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
How to set the timer
MTD8 is 240Volt din rail timer max load 15 amps
How do I set in Automatic mode, seems to only work manually since loss of power?
1) Power outage is major cause of timer failure. Power surge occurs when power is restored, and electronics are susceptible to surge. This includes water softerer, treadmill, electronic water heater, timers, etc.
Timers should be unplugged when power goes off.
Of all timers on market today, only one instruction manual says to unplug timer with power loss. However many people write fixya saying their timer, and electronic water heater control etc stopped functioning after power loss. Probably other products have same problem, but I work with timers and water heaters and see only that slice of the world.
2) Question posted under Woods 59377.
Several timers look identical or similar.
59377 timer has non-replaceable rechargeable battery, some similar timers have AA battery.
If timer has battery, change battery.
Then reset timer to restore functionality. Press reset button for a few seconds with paper clip.
3) If timer function does not restore after reset, then timer is bad.
Buy similar timer at Lowes or Target, and return defective timer in new package.
4) If function is restored, then re-program timer
Open following link for timer instructions showing how to reset timer and re-program timer:
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
2helpful
I bought a Major Tech Mtd9 programmable timer but there are no instructions included, only features. I have no idea how to set the date and the timer. Say I want the light to switch on at 6PM and switch...
First press reset (use pen or paperclip). Press MOVE button until you get OFF at right bottom of screen, then press SELECT to select mode (to set time and date, to select on/off for the 2 timers or to select rundown timer. Use OK to move to different setting, eg. hour,minute, year,month day etc. Use SELECT to change up one digit at a time. Play around with buttons to change settings, for example to have timer on on a specific day of the week or everyday etc. When it is set, use move to change from OFF to AUTO, timer will then switch on and off at set times. Hope it helps
Lost the instructions T1032-33-34-35 can we get them?
http://waterheatertimer.org/pdf/Aube-T1032-timer.pdf
Aube is a Honeywell product I believe:
The timer seems revolutionary for not requiring a Neutral wire, yet requires no battery either.
Advantage: No more confusing wiring. Simple 7-step programming.
If old switch has 2 wires, the Aube changes to 2-wire application
If old switch is 3-way, the Aube changes to 3-wire application, the only major change is jumper on other 3-way switch
Timer replaces ordinary wall switch:
Timer replaces 3-way switch
2helpful
Adjusting mtd carb. i there a set turns for the adjustment screws
Basic screw adjustments to start with are 3/4 of a turn from the farthest "in" setting. Don't tighten down on the screws too hard, turn down just enough intil they stop, then turn out from there. After engine starts, you can fine tune the idle speed and then the high speed crews.
Top Major Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Major Hardware and Accessory Expert? Answer questions, earn points and help others
