SOURCE: HEATER MAKING LOUD NOISES
Check the draft inducer motor for any partial blockages or dibri.
I've seen sticks, birds nest particles and pieces of deteriorating fan blades (squirrel cage type fans) cause this.
You might also find that the inducer motors bearing are going.
If its a loud vibrating grinding type noise, I'd suspect bearings or missing pieces of the blades. (unbalanced)
If it's a clanking type noise I'd suspect loose items hitting the fan.
The inducer motor will only operate right before and during burner operation, while the blower motor can operate at any time depending on your setting.
SOURCE: Flame Shooting out the front
You clearly have a gas leak. Inspect the suspect area for loose connections like the gas delivery pipe to the burner assembly. Try to reconnect them. If there is a hole in it you can use some muffler repair adhesive but I would just get a new part. Often the company will send you free parts as a good gesture to assure encourage repeat business. Check out the links below. The second one offers free shipping.
www.charbroil.com/CharBroilWarranty
www.clagrills.com/grillparts/charbroil/charbroil-grill-parts-home.htm
SOURCE: my 8000 btu a/c is spraying water out the front and making loud n
It needs to be taken apart and cleaned.Tom
SOURCE: my all pro 150000 btu
The first thing to check would be the fuel filter from the tank to the nozzle.
Then check the input and output filters on the back of the pump housing.
Here is a link to a service manual.
http://www.desaparts.com/service_manuals.html
Thanks
M Cramer
www.allpartsinc.com
