Home Logo
C
Constance Staresinic Posted on Jan 22, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 913 keeps chirping ... even after new batteries were installed - how can I stop the chirping
Stan Naramore
Level 3:
Guru:
  • Master 531 Answers
  • Posted on Jan 22, 2019
Stan Naramore
Master
Level 3:
Guru:
Answers
531
Questions
Helped
208998
Points
2468
If you are using rechargeable batteries change all batteries to normal batteries If you are using cheap generic batteries change to brand name batteries. Clean all contacts carefully with WD-40 Contact Cleaner
5 Related Answers
Anonymous
  • Posted on May 06, 2009
SOURCE: wont turn on
IT COULD VERY WELL BE THE BATTERIES YOURE USING. IF NOT YOU MAY NEED REAL TECH SUPPORT. I ALWAYS USE DURRACEL ...CHEAP BATTERIES ONLY LAST A FEW DAYS. AND 1 DAY IF YOU USE THE VIDEO.
Anonymous
  • 34 Answers
  • Posted on Oct 25, 2009
SOURCE: smoke detector won't stop chirping.
it may need to be cleaned or it is bad may need to be replaced
Anonymous
  • 3 Answers
  • Posted on Nov 13, 2010
SOURCE: CHIRP EVERY 30 SECONDS EVEN
Unfortunately you will need to replace thew unit. CO alarms have an effective lif expectancy of about 4 years. After that point they are no longer reliable or accurate and should be replaced.
richie46
  • 12962 Answers
  • Posted on Oct 27, 2016
SOURCE: My hard wired smoke alarm has had a new 9 volt battery installed and even a second new one installed and is still chirping 4 times every 30 seconds.
On many of the newer smoke alarm installations, all of the units are wired together so that if one goes off, it triggers all of the others so that no matter where you are you will definitely hear the maddening noise of the alarms! And if one of the other units has a bad or weak battery not only will it chirp but so will the others.
Only way around this is to cut any and all wires going to each smoke detector. They will still work because each has its own battery but there will be no more triggering of other units.
stevenpack
Steve Pack
  • 7128 Answers
  • Posted on May 09, 2018
SOURCE: I installed a new battery 3 weeks ago. It started chirping yesterday. New battery again and it has not stopped chirping since.
if you are talking about smoke detector replace it. the life is about 2-3 years.
1helpful
I installed a new smoke alarm battery only 3 weeks ago. It started chirping yesterday. New battery and it has not stopped chirping since.
The battery you installed may be defective or expired, replace it again with a major brand like Energizer
May 09, 2018 • The Optics
1helpful
After replacing the batteries on my dsc smoke detector the unit continues to chirp. the batteries are new do i need to do something to stop the chirp
try replacing the batteries again and make sure they are in correctly-ive put them in more than once and found out it was the brand new batteries that were bad and also installed them incorrectly too
Nov 04, 2017 • Home
2answers
My Kidde Model 1285 keeps chirping even after I changed the batteries, any ideas why?
Be sure you are using a well known brand battery. The store brands, in my my opinion generally are not quite up to par. Try this and see if the chirp will stop. Thanks for asking me.
Rental mgmt company just installed Kidd 112020/40/80 (don't know which one. It does the same thing the previous smoke alarm did - wakes me up in the middle of the night! It chirps every hour, every 30...
They only chirp for two reasons:
1. The sensor is past its useful life and needs replaced
2. There is a power issue with the battery. Even the ones that are hardwired into the electrical system need a battery.
2helpful
My alarm is chirping every 30 seconds. This is my second one. no light .
An intermittent chirp usually indicates that the battery needs changing, or a battery needs to be installed. If this is a new unit that came with the battery already inside, there is probably a tab located between the top of the battery and the contacts that needs removing before the unit will stop chirping.
9helpful
3answers
Smoke alarm keeps chirping.
I am having problems seeing if you have any more data besides "smoke alarm keeps chirping." so I will ask; have you tried changing the battery?
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
