Humidifiers Logo
Jackie Anderson Posted on Jan 21, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where do I put essential oils in the Mainstay cool mist humidifier pj8005
graybeard32301
Level 3:
  • Master 382 Answers
  • Posted on Jan 22, 2019
graybeard32301
Master
Level 3:
Answers
382
Questions
0
Helped
128461
Points
1328
Remove the mist direction cap (dark plastic piece where the mist comes out.) You should find a small plastic cup with an attached cap. Put the essential oil in the cup, snap on the cap, and put it back into the mist exhaust, and replace the mist direction cap.
5 Related Answers
Anonymous
  • 482 Answers
  • Posted on Dec 16, 2007
SOURCE: mold in vicks cool mist vaporizer
if you can take it out side and plug it in, put some bleach in it and let it run for a few minutes. then wash it out and run the rest of it out.
Anonymous
  • 7 Answers
  • Posted on Feb 12, 2008
SOURCE: Humidifier makes a huge noise and no mist
According to the Crane's Troubleshooting section:
The power light is green but there is no mist being emitted:
- Check that there is water in the tank.
- Check for possible lime deposits on the water level sensor or the nebulizer.
- Make sure that nothing blocks the vapor output slots.
- Check that the fan vent on bottom of humidifier is not blocked.
- Empty the humidifier and rinse the water basin with cool tap water and allow to dry for 15 to 30 min.
This next part may or may not be relevant.
Humidifier power light is staying red and not turning green. Or, Humidifier is working then stops:
- Ensure that water level sensor is assembled properly.
- Clean water float.
- Call service center and request replacement water float.
Barring that, here is the service center contact info:
Dart Warehouse Corporation
Tel: 1-888-599-0952 (Business hours Mon-Fri 9:00 am - 4:00 pm Ct)
Website: http://www.crane-usa.com
1835 Ferry Road
Naperville, Illinois 60563
Anonymous
  • 7 Answers
SOURCE: Crane Adorable One Gallon Cool Mist Ultrasonic Humidifier
I posted the instructions for cleaning the unit a little while ago, but under a different Crane humidifier product. See http://www.fixya.com/support/t253969-cleaning_instructions
Anonymous
  • 123 Answers
  • Posted on Apr 18, 2008
SOURCE: Replacement tank for Vicks Cool Mist V3500N
It doesn't look like they sell any replacement parts for this machine. I would call the manufacture and see if they will sell you one.
Good Luck.
A
Anonymous
  • Posted on May 30, 2008
SOURCE: Humidifier mist won't come out of tube
sounds like the small fan that is located in the base isn`t pushing the mist out. unplug it then take all the screws out of the base. there are screws under the black foam stands too. be careful not to touch anything that looks like live wires while you look inside then look inside while it is pluged in. it should turn. check for something blocking it like lint or dirt..you may be able to clean around the shaft with w d 40
How do I clean the dual tank ultrasonic humidifier membrane
Air Innovations Clean Mist Ultrasonic Dual Tank Humidifier ...
www.qvc.com/Air-Innovations-Clean-Mist-Ultrasonic-Dual-Tank-H...
QVCAir Innovations Clean Mist Ultrasonic Dual Tank Humidifier. Air Innovations ..... I did not realize that you needed a special filter if you have hard water. If you do ...
Sharper Image Dual Tank Warm &Cool Mist Ultrasonic ...
www.qvc.com/Sharper-Image-Dual-Tank-Warm-&Cool-Mist-Ultras...
QVCSharper Image Dual Tank Warm &Cool Mist Ultrasonic Humidifier ..... I've only had toclean the membrane once since I purchased it, and that's really not a big ...
How to Repair an Ultrasonic Humidifer ' eBay
Dec 14, 2015 • Humidifiers
S45U-A Cool Mist. Where can I get instructions?
Cool Mist Humidifier - YouTube
? 4:37
www.youtube.com/watch?v=DVB7Jf1kUj4
Apr 14, 2011 - Uploaded by ricks2516 http://coolmisthumidifierreviews.org Cool mist humidifier reviews showing the features of a cheap humidifier ...
Sep 30, 2015 • Humidifiers
I bought a cool mist humidifier an added 1 gallon of distilled water too the tank. I added 1 teaspoon of baking soda but still no mist. What should i do?
you may need to empty the water that went into the base and retry putting the top tank back on sometimes too much water gets into the bottom and it wont put out vapor. at least mine does that and it is an ionic cool mist humidifier which means uses no filter
Mar 03, 2014 • Humidifiers
Wont blow out mist
it has a quiet operation when you got it brand new did it put out mist
Does the Sunbeam Ultrasonic Humidifier Model 696-12 have a filter?
This humidifier is AMAZING. I’m a huge fan of using essential oils (lavender, lemongrass, spruce, rose, sandalwood etc) and I picked this up from a thrift shop, added some essential oils to the water and my house smells wonderful.
Essential oil diffusers are virtually the same thing design wise except cost a fortune. This is my best diffuser! I paid $10 for it and it works so good, throws off a ton of mist which I love (it’s so dry here) and I will enjoy owning this unit for years to come. Only thing is to gently clean the little ionizer part with the brush gently and keep it clean. Also..this unit unlike newer ones does NOT shut off automatically so keep an eye on it. Running it dry might cause it to burn out.
7helpful
2answers
WHY DON'T MIST COME OUT OF MY HUMIDIFIER
with cool mist humidifiers your not suppose to see any mist. if it's a warm mist there should be. but by your model number i'm finding that it's a cool mist. that's why your not seeing any mist.
Cleaning a Cool Mist BCM6100U Humidifier
usually it calls for one cap full per gallon of water that the unit has. what you do then is that you put the solution in the water then you put the tank back on the base and then you turn the unit on and let the solution run through your unit.
6helpful
2answers
We have a Sunbeam Cool Mist Ultrasonic Humidifier that we bought just over 2 months ago. Up until a couple of days ago, it was producing mist and running just fine. I cleaned it with the brush and got the...
I have this same problem. And cool mist humidifiers DO produce mist. I have had my humidifier for a while now (6 years) and have never had any problems. But after the most recent cleaning, it worked at first, but now seems to not be working anymore... Am also wondering if there is anything I can do to remedy the situation?
Family Care cold mist humidifer
cool mist humidifiers don't put out any mist. only the warm ones do. now if you put your hand over the area where it's coming out for about 2 minutes and take it away your hand should feel damp. almost clammy. if it feels like that the unit is working fine. so your not doing anything wrong. if you have any other concerns please let me know.
Top Humidifiers Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Humidifier Expert? Answer questions, earn points and help others
