20 Most Recent
Vicks Warm Steam Vaporizer 1.5 Gallon Humidifier Questions & Answers
Hi have a vicks warm
The easiest ans simplest way to clean it, is too mix a 50/50 solution of White Vinegar & Bottled Distilled Water (enough to fill the tank) and fill the the tank with the solution. Allow it to set for 30 minutes, then turn the unit ON. Allow it to run, until the tank is half empty. Pour out the remaining solution and fill with the Bottled Distilled Water Turn the unit ON and run until the tank is almost empty. Following these instruction will remove all the lime and calcium build up in the unit.
Tip: Using bottled Distilled Water rather than Tap Water, will totally eliminate calcium and lime buildup.
I hope this helped you and thanks for choosing FixYa.
My vaporizer is making a spitting sound -
No salt, unless you had 0 steam - to stop water spit, throughly clean the water tank, just as clean as new. It will work like new if the tank is as clean as new! I dont know where the small particles of dirt come from, but trust me, I just went thru this with mine, it's got dirt in it!
Where do I add the
I believe that you just have to add it with the water in the container. Here is a video detailing the product and its use.
http://www.expotv.com/videos/reviews/11/128/VicksV-105SG10GallonWarmMistVaporizer/257785
I am sorry but i didn't understand if i need to
the vapour oil medicine is put in the little reservoir right at the front top on the blue unit that sits on the plastic base... about a tablespoon. It will still be there after use, but it's only oil residue, after the medicine has evaporated with steam. clean it out with paper towel and refill for each use when needed. Only salt is added to the water, not the oil...
How to stop humidifier from spitting out water
Humidifiers, depending on brand will spit out a little water as that is the Idea to get moisture into the air, but you can try not filing it so full, this one is steam so I would look into owners manual as to how to clean it , you may find that it has collected calcium deposits not allowing it to vaporize the water properly.
Vicks caporiser is spitting water instead of steam
Clean the unti - and do not add salt. I live in a major hard water city...and was amazed at how much dirt the tank collected. I tried adding salt to to stop the spitting, which did make a lot more steam, but did NOT stop teh water spit. I also noticed, with salt added, water in tank would only last 4-6 hours, not the 18-24 hours it should. I just figured it out, and now mine works great again, and does not spit. I cleaned the water tank throughly, several rinses, then wiped out entire inside. If you want it to work like new, you have to keep your tank as clean as new. I am going to start filtering my water that I put in with a double pantyhose I made simply so there no more dirt ~ a clean tank will fix the problem, it did mine :)
