Measuring Tools & Sensors Logo
Jim Fawcett Posted on Jan 19, 2019
What is the meaning of HH in the outdoor temperature position?
Diogo Cruz
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Jan 19, 2019
Diogo Cruz
Contributor
Level 1:
New Friend:
Answers
5
Questions
Helped
721
Points
35
Follow this link similar problem.
http://www.fixya.com/support/t9858391-taylor_indoor_outdoor_thermometer_hh_h
2answers
Radio Shack outdoor thermometer remote sensor 63-1026 reads LL.L Replacing batteries and reset didnt help. How to fix?
Try cleaning the outdoor thermometer transmitter unit by opening it up enough to spray compressed air (Ultra Duster or similar) on the temperature sensor. It fixed the hh.h error for me.
I just put new Energizer batteries in both the outdoor and indoor units. Followed directions. The receiver is displaying HH when I ask for the high.
Very likely you have high pressure in your area. HHH means that the pressure is higher than the unit can read. Check local barometer readings to confirm.
Outdoor temp reads HH.H. How do I get it to display the temp again?
Mine reads HH.H on outdoor after a hailstorm. The wire was broken to the outdoor sensor.
I have an Acurite 822-RX thermometer that shows HH as the outdoor temp, even after replacing the batteries in both the base and remote units. How can it be fixed or reset?
HH means it is showing the high temperature you (most likely accidentally) set with the MAX MIN / + button, which is easy to do when setting the clock. Just press that button again until the reading appears.
What does hh.h mean on display
I'm assuming it just stands for "High Humidity". It wasn't raining at the time, but it sure had been earlier, so perhaps if it's over some number (like 90%), it just says "HH".
2helpful
What does Comfort Zone II Error Code E5 mean?
If I'm not mistaken, it seems like it means there is a problem with the outdoor temperature sensor. This is strictly from memory though and I could be wrong. If you press the up and down arrow buttons at the same time it should display the outdoor temperature for a few seconds and then the indoor humidity. You might try this to see if it displays an outdoor temperature that is close to being right. If it doesn't there is a good chance the sensor is bad or there is a broken wire somewhere.
I hope this helps!
Top Measuring Tools & Sensors Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
