20 Most Recent Zircon Dimension Pro 4.0 Ultrasonic Measuring Tape Questions & Answers
2answers
Need user manual for w5746
Same exact features, buttons and functions as this manual by Irwin.
http://www.irwin.com/uploads/documents/36_laser_tape_25.pdf
4/17/2024 8:59:53 PM • Measuring Tools... • Answered on Apr 17, 2024
Rf tech 433mhz manual model 217S31
I want to use an old sensor forgiven during 30 years. I have no more manual, off course. Thanks for your answer
3/26/2024 11:42:40 PM • Measuring Tools... • Answered on Mar 26, 2024
What are the readings on a meoisture meter measured in?
Most moisture meters measure the moisture content of wood or concrete is measured in percentages. So if the reading says 15 that means that there is a content of 15% moisture in the concrete.
3/16/2024 7:34:55 AM • Measuring Tools... • Answered on Mar 16, 2024
How do I change the temperature display on a Digitech XC-0366 weather station from Degrees F to Degrees C?
Pressing the - (minus) button on the back toggles temperature units. Pressing + (plus) toggles barometric pressure units.
2/19/2024 4:57:31 AM • Measuring Tools... • Answered on Feb 19, 2024
Will one of the newer sensors work in place of my 1457 sensor?
It's possible that one of the newer sensors could work in place of your 1457 sensor, but it depends on the specifications of the newer sensors and the compatibility with your base unit. The I MAX1457 sensor, which is a highly integrated analog-sensor signal processor optimized for piezoresistive sensor calibration and compensation. However, I have no information about its compatibility. If you're looking for a replacement sensor, I suggest contacting the manufacturer of your base unit to inquire about compatible sensors. Alternatively, you can check the user manual of your base unit to see if it lists compatible sensors. Garage door opener sensors are not universal. Safety sensors can only communicate with garage door openers from the same brand.
1/21/2024 4:20:12 AM • Measuring Tools... • Answered on Jan 21, 2024
DSE Z111 Weather Station: Is the wireless sensor available for sale?
Unlikely unless you know the secret maker name and can find them in China. At the moment, no one has heard of it apart from here on Fixya. All questions need FULL 'make model (what it is)' please. https://www.google.com/search?q=dse+z111 ..
1/20/2024 1:59:56 AM • Measuring Tools... • Answered on Jan 20, 2024
How can I adjust the time on my weather station model #sgr72914?
  1. Access the Time Setting Mode:
    • Locate the 'Set' or 'Settings' button on your weather station. This button is typically found on the front or the back of the unit.
    • Press and hold the 'Set' or 'Settings' button for about 3 to 5 seconds. This action should access the time setting mode, where you can adjust the time.
  2. Adjust Hour and Minutes:
    • Once in the time setting mode, use the 'Up' or '+' button to increase the hours and the 'Down' or '-' button to decrease the hours.
    • After setting the correct hour, press the 'Set' or 'Settings' button again to move to the minutes setting.
    • Use the 'Up' or '+' and 'Down' or '-' buttons to adjust the minutes accordingly.
  3. Confirm the Time:
    • Once you have set the correct time, press the 'Set' or 'Settings' button again to confirm and exit the time setting mode.
  4. Check the Time Display:
    • After setting the time, check the display to ensure that the time is displayed correctly.
1/7/2024 9:28:03 AM • Measuring Tools... • Answered on Jan 07, 2024
Starrett Tape Measure. Can I Replace a 1.5 volt Battery with a 3.0 volt Battery in it?
Question edited for clarity. Question moved from Motorcycles category. Of course not! You will burn out all the electronic components. You can't just double the voltage. Conversely you can't put a 1.5 volt battery in place of a 3 volt one. Get the proper battery. https://www.starrett.com/contact-us# ..
12/20/2023 4:55:24 AM • Measuring Tools... • Answered on Dec 20, 2023
Ascot Weather Station. Instruction for reset times please.
Ascot weather station manuals
Manua.ls https://www.manua.ls > Ascot > Weather station You are currently on the Ascot weather station manuals page. Choose one of the products to go directly to the manual for this product.
Ascot weather station user manual
Manuals.co.uk https://www.manuals.co.uk > Ascot > Weather station For those looking for a simple and straightforward setup, Ascot Weather Stations provides a quick start guide with step-by-step instructions to get you up and ...
User manual Ascot AUK-WS-32 (English - 6 pages)
Manua.ls https://www.manua.ls > weather stations > Ascot To install and set up the Ascot AUK-WS-32 weather station, you should begin by securely mounting the sensor unit in an elevated outdoor location, ensuring it is ...
Ascot GT-WS-06s user manual (English - 40 pages)
Manuals.ca https://www.manuals.ca > weather stations > Ascot User manual. View the manual for the Ascot GT-WS-06s here, for free. This manual comes under the category weather stations and has been rated by 2 people ...
Ascot Weather Station User Manuals Download
ManualsLib https://www.manualslib.com > Brands > Ascot Manuals Download 1 Ascot Weather Station PDF manuals. User manuals, Ascot Weather Station Operating guides and Service manuals ... Operating Instructions Manual.
12/10/2023 5:27:32 PM • Measuring Tools... • Answered on Dec 10, 2023
Ascot Weather Station. Instructions for operation please?
12/10/2023 5:08:32 PM • Measuring Tools... • Answered on Dec 10, 2023
AcuRite Professional Weather Center 01602BPDI. It eats the outside batteries. Batteries last about 2-3 months till low battery power shows inside with -40 degrees plus other false readings.
My National Geographic Weather Station is the opposite. The outside sensor only indicates the temperature, but the single CR2023 battery lasts a year. The inside unit on my desk lasts around 5 - 6 months and lets me know if needs a battery by showing the outside temperature as ' -- ' Although the manual says 'rechargeable batteries are not recommended', I would try 4 Sanyo Eneloop batteries. Or you could contact Acurite Support and ask them if your battery use is excessive?
01602BPDI - Professional Weather Station Instructions
AcuRite.com https://www.acurite.com > 01602-instructions Professional Weather Center model 01602BPDI. Questions? Contact Customer Support at. (877) 221-1252 or visit www.AcuRite.com. SAVE THIS MANUAL FOR FUTURE ...
12/10/2023 5:06:00 PM • Measuring Tools... • Answered on Dec 10, 2023
Digitech 4-LD1197-6 manual
istruzioni per cambiare l'orario
11/10/2023 5:53:23 PM • Measuring Tools... • Answered on Nov 10, 2023
Does anyone know how to set the time on a Flink weather station KW9007W?
See section 9 (Time and Alarm Setting) of this manual at page 8. Microsoft Word - KW9007W-SM_2_WWVB VERSION RC-NONE.doc (fccid.io)
11/8/2023 12:40:26 PM • Measuring Tools... • Answered on Nov 08, 2023
Quadra-Chek 200 advanced digital measuring readout system is measuring parts 5 times smaller than they are. How do I fix this?
Question edited for clarity. Question moved from Cars and Trucks category. A bit specialised for Fixya, but I just read the manual. Scale Factor = Section 7-45 Page 295. Change from 5.000000 to 0.000000 Or try removing the battery again for 10 minutes and replace. There doesn't appear to be a hard reset function. Or the maker support Metronics, Inc. Bedford, New Hampshire, USA http://www.auto-met.com/metronics/ab05.html
METRONICS - 30 Harvey Rd, Bedford, New Hampshire
Yelp https://m.yelp.com > biz > metronics-bedford Metronics Photos · Map · 30 Harvey Rd. Unit 1. Bedford, NH 03110. Directions · (603) 222-5600. Call Now ...
9/19/2023 4:53:28 PM • Measuring Tools... • Answered on Sep 19, 2023
Xc 366 forecast not working
6/23/2023 9:53:52 AM • Measuring Tools... • Answered on Jun 23, 2023
Zircon Dimension Pro 4.0 Ultrasonic Measuring Tape Logo
1 questions posted
Top Zircon Measuring Tools & Sensors Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Zircon Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Zircon Measuring Tools & Sensors
Most Popular Question
robinair 34788 display contrast
  • Measuring Tools & Sensors
