SOURCE: Clogged Dispensers
Sounds like a burst water line inside, if you made sure there is water available, and you hear it pumping. Either that or a solenoid valve is not activating. Must remove unit and pull the cover to investigate.
SOURCE: Viking fridge water and ice not working
Yes....a totaly clogged filter COULD cause the problem, but the water solenoid may be the culprit. I'd call a service company to look at it.
SOURCE: Whirlpool sideby side fridge - water dispenser and
HI. In most cases, this will be the result of a failed inlet valve. There are some other causes, as well. I would suggest to inspect the water lines for freeze over, and obstructions, as well. Normally, the inside lines will freeze over, thus, producing ice within the lines, this will obstruct the flow. Another issue will be the filter. Once this device reaches its filtering limit, it will shut down, thus, preventing the flow to the dispenser/ice-maker assembly. Once you have ruled out these more common issues, Move on to the procedure below for the inlet inspection.
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush, or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
SOURCE: My Keurig B60 is suddenly
I solved it by running the machine a couple of times without a K cup in it. The second time through, a few grinds ended up in the cup. After that, the machine works fine.
SOURCE: I need the manual for the Keruig B60 coffee maker
mcdevito75 here, Contact green mountain coffee, they handle Keurig products and accessories at, 888-879-4627 or service rep. Chris Connell at 781-205-7282 Hope this helps.
