Remove the water hose from the back of the washing machine look inside the valve there will be a screen in there clean the screen do not remove it and throw it away if you can get the screen out without damaging it you can reinstall it but do not run the machine without that screen in the valve
SOURCE: only cold water in my tub hot only trickles
Usualy when this happens you need to change out the cartrage that controls the water. try to find your faucet at the link below. If you find it click on it scrol down and you can view the manual. It will terr you how to change it out.
http://www.deltafaucet.com/bath/index.html#tubshower_
Good Luck
SOURCE: cold water trickle hot water runs good
turn off water valves at wall, disconnect the supply hoses from the washer. where the hoses connect to the washer, there is usually a stainless steel screen/strainer inline on both the hot and cold inlet. corrosion on the cold side is pretty common. Menards, Lowes Home Depot stores sell the replacment screeens.
SOURCE: water just trickles
Do you have stop valves that are built into the faucet body? Some newer faucets have stops built into the unit on each side of the manifold. Make sure they are open. If you don't, then remove the guts from the manifold body and have someone turn the water on slowly to make sure you don't have something clogged. Also depending on the style have cartridge like guts and can be put in upside down. I'm not sure what you have and I wouldn't know even if you gave me the model number. If this fails, you need to contact the manufacturer. They usually have an 800 number that you can call. Good luck!
SOURCE: water just trickles out
Some of the new units have stops installed on the valve itself. Make sure they are open.
SOURCE: hot and cold water trickles from faucet--seems nearly clogged.
The debre from turning off the valves comes through the lines and clogs up,usually the aireator,the screen at the end of the faucet. Take aireator off ,,colena and reassemble. If that does not work,disconnect the lines at the shurtoff agaoun and look for hte obstructions for the aireator back to the shurtoffs.
