I had the same problem with my Kenmore Model 11022956102 washer and first thought that it was the water inlet valves. So I replaced them, but found the problem continued. After about 25 seconds into the rinse cycle the water only trickled in. Checking with a voltage meter I found that I lost 120V at terminals 3 & 5 on the washer temperature controller after 25 seconds. Even though the wiring diagram doesn't show the water temperature control board, since it's full of resisters and capacitors, I figured it was the most likely problem. So I ordered a remanufactured board from Parts Simple (#3407125), received and installed it. The 17 year old washer is now working fine once again. I hope this helps someone with the same problem. /s/ Paul
Clutch needs to be replaced that is why it is not spinning out. There is a clear rubber hose that goes from the fill valve on the top left of the machine down towards the bottom of the tub on the right side under the cabinet. Check and see if that hose has a hole in it of possibly came loose on either end. If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out. the machine probably has a cold only final rinse so it won't work properly.
Its the transmission. Try to find a used appliance store in your town. Most save used parts and you should be able to pick up a used tranny for around 100 bucks.
This issue usually occurs due to kinked drain pipe, clogged
drain filter or drain pump. First make sure that the drain is not clogged and
remove clogs if present. If no visible lint is present then remove the lower
front access panel to check the drain filter and drain pump for any clogs,
you'll need to clean the drain filter and drain pump completely. Hope this
helps... Please post back for any further assistance. Daniel
Jun 26, 2011 - Uploaded by XR600RQJ
Washing machine Indesit starts to flash for longer and longer ...How do you unlock the door when the power is off?? every time i turn it ... My washing maschine ( Indesit WITXL 129 ) had the same problem - 6 from 9 LED lights ..
If the lid switch is faulty, or incorrectly adjusted, the drive motor is prevented from running. You do not say whether your repair man replaced the switch or the mechanism, but draining and spinning will only happen when the lid switch is engaged.
Under the lid there should be a small hole with a push down flap and that should be the automatic stop, which can either be a bad switch under the top of the machine or could be a broken trip/ prong on the lid that pushes this button when the lid is dropped. When the machine reaches it's spin cycle time leave it turned on and raise the lid push down on this flap with something careful to keep hands out of the washers tub and see if it works then!
