Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the sites linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/ http://homenol.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
{View the site in web view by Mobile or by a desktop to see the search box. Mobile view has no search box.}/
SOURCE: RCA VR601AHF
I just had this same problem. I thought that the timer was stuck and was the reason why the VCR wouldn't play. I just moved and thought the unit got broken in the move. However, I think it was just not hooked up properly to the TV. I unplugged it, plugged it back in, and got it hooked up properly and it started working again (I tested the connection with a DVD player first). The flashing timer light went off as soon as I reset the clock. It seems odd that having it not hooked up properly should stop the VCR from playing, but that is what seemed to happen in my case. Hope this helps.
SOURCE: PROJECTOR POWERS DOWN
This would appear to be a bulb that has reached end of life -- or the projector thinks that it is because of hours. Usually most bulbs are 1000 or 2000 hours. Depending on your projector there are different ways of checking bulb life hours -- if you Google your projector model number and "bulb life" you will usually get a post on how to check these hours. Also, if it is a new bulb and you haven't reset the hours counter, it may need to be reset (however you also don't want to wait too long before changing a bulb that has reached EOL since they can and do explode sometimes taking out the projector with it).
SOURCE: Err CF
TRy and reformat the CF card through the camera. Youll lose the pics for sure but you cant see them anyway. You can also check for bent pins in the CF slot. Sometimes if you shut down the camera in mid write to the card, itll mess up the cards FAT (file directory)
SOURCE: no image in lcd viewfinder
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
SOURCE: rca hd tv d52w15
that model is famous for having bad flybacks. fortunately they arent exspensive and there easy to replace. you can get a new replacement at the following link for less than 50 bucks and they give free instructions on how to install it properly.
http://servicemanuals.vstore.ca/
