Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://elektrotricks.blogspot.com/
Blinking codes details to many popular brand TVs are given. If blinks continue without any pause, the main board is faulty. Search the sites by type in the brand name to your set, in its search box on the right side. View it on a desktop or in web View.. Mobile view has no search box.
Investigate for a failing power supply
SOURCE: rca L32WD22 won't turn on...is there a fuse? If
Hello
did you see the standby light? if no you have problem in main power section maybe the fuse is blown you can locate the fuse at the power main board, or if the standby light is light up the problem is the inverter power supply and this section is need to diagnose to find the defective parts...
Angel
Thanks...
SOURCE: RCA L32WD22 with no picture.
The backlight has failed. May be the power supply for it, the inverter board or the lamps. Not something you can fix unless you are a tech.
SOURCE: i have a rca l32wd22 screen weht black with no
Aboyd992,
Take your tv to a service center and ask them to fix it. If they cant...
Have them make out a work order and then you call 1-877-297-8391. The people at the other end ot the tele number will give another tv
SOURCE: tv LCD RCA model L32WD22 what ic replacement can I use?
servicios,
Close the the unit up as you had before opening. Take the unit to a service centre and have them fix it. They don't have manuals to repair so, when they say, "We can't fix this" you take the work order and call1877-297-8391 and they will get you a new tv
SOURCE: My rca L32wd22 tv won't
First, remove it from the wall plug, fix it back in and try again. If that doesn't work, it means there is a problem, read further.
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
