My dog usually lays by me when i watch TV. One day he kept looking up to the ceiling and is afraid of the sound of the curtain. I held him and stood on the couch while opening and closing the drapes and he now refuses to go back into the same room
SOURCE: freezer door not sealing
Probably a defective defrost timer. Try to find the timer. It is usually underneat in the back. When you find it turn the knob slowly click by click. (You may need a screwdriver or knife) turn just until the compressor stops. Let it stay in defrost for about 1/2 hour. turn the knob until the compressor starts let it cool down several hours. Then do it again. If this solves the problem replace the timer. While you are waiting to do this Defrost it at least twice a day by turning the knob.
SOURCE: My DLP TV made a loud popping sound then went off
first. unplug the set for 5 minutes and see if it will reboot. if it does not the you have 2 problems, the chassis is also bad. next open the lamp door cover, it is behind the speaker grill, and behind the lamp door.
take out the lamp and see if it has broken on the inside if it has it needs to be replaced. mits will send you one i believe it is about 100.00 the number is 915P020010. if the lamp looks ok then the color wheel has probably fallen apart.if this is the case the light engine need to be repaired. check out www.tv-techs.com
SOURCE: Lost sound for DVD player
PRESS THE SIGNAL SELECT BUTTON THAT WILL ACTIVATE THE 5.1 SURROUND. IT WILL CHANGE FROM ANALOG TO DIGITAL OR DVD/LD TO DVD 5.1.
SOURCE: black decker drill keyless chuck won.t open !
hold the back of the chuck with channel locks or a vice and use the same channel locks on the front and open the chuck manually it should work and you can get to the screw to replace it or the hand chuck. this can be a little frustrating but hang in there and you'll be a pro shortly.
SOURCE: door wont close unless the key pad is held down day or night time
the photo eyes are out of alignment or have dust on the lenz, clean them off and align them, and your proplem will go away
