20 Most Recent Janome Memory Craft 9000 Computerized Sewing Machine Questions & Answers
3answers
I have a Memory Craft 8000. The computer screen
Try to recalibrate the machine.
With the machine off Hold down the three buttons that are on the front of the machine(start/stop.reverse and auto lock). While the buttons are depressed turn the machine on. A box with the sign + will come up on the screen under it you will see another + that is the one you touch. Then several more + come up.
Just touch each one as they appear. Then the message test complete will come up. Turn off machine and wait at least 5 seconds. Then you can turn the machine back on and hopefully fixes your problem. It checks for errors and fixes them. If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
4/21/2023 3:43:53 PM • Janome Memory... • Answered on Apr 21, 2023
Want to change language
http://www.sewingpartsonline.com/instruction-book-janome-and-newhome-9000.aspxhere is a link for a manual or you can check on youtube for a video
1/12/2023 1:29:57 AM • Janome Memory... • Answered on Jan 12, 2023
3answers
Janome 10001 - bobbin winding starts okay but it
Take it to a Janome dealer for repair.
7/11/2022 6:21:15 AM • Janome Memory... • Answered on Jul 11, 2022
Anyone have any extra memory cards for Janome MC 9000 for sale?
Question moved from Cameras category Here apparently https://www.delawaresewing.com/janome/janome9000web.htm ..
1/11/2022 1:04:28 AM • Janome Memory... • Answered on Jan 11, 2022
2answers
I need a new circuit board for a new home memory craft 6000
the board which you require will only be provided with the janome service center. still you can check out this link  http://www.sewingmachines.com.au/janome9000.html
for more details on any other require ment or contact this link to ghet them the required fboard for you.
11/7/2021 2:02:46 AM • Janome Memory... • Answered on Nov 07, 2021
3answers
Janome MC 9000 off touch screen calibration
Thanks guys
I remembered the fix!!
On the Janome MC 9000
To calibrate the touch screen
1. Turn off
2. on Sewing arm above needle there are a series of buttons
3. Hold down bottom 3 buttons
4. While holding turn on machine
5. Using scribe
6. Touch the centre of each + as it appears
7. It will go Centre bottom rh centre top lh as you select each + position it moves of it's own accord.
8. Turn off machine
9 Turn on and test.
Important sometimes this does not entirely fix prob!!
Simply do it again "Yahoo""
Some mechanics will try to tell U the screen is on it's way out
Bollocks just calibrate.
Thanks
CYA
1/31/2021 7:47:26 PM • Janome Memory... • Answered on Jan 31, 2021
Janome 9000 willl not work when turned on
My Janome 9000 has always done that. I can prevent it by raising the needle when I first start the machine, getting it to sew quickly or raising the needle and letting the machine sit for a few minutes. I think my computer wants to warm up a minute. As you can see I.m not a technical person but it works for me.
1/3/2020 6:15:37 PM • Janome Memory... • Answered on Jan 03, 2020
7answers
Janome memory craft 8000
We have about 30 electroluminescent backlights for the 8000 still available .These are not original Janome parts. You will need a Janome service person to install then for you as it requires taking apart alot of the machine to get to the display. We can provide instructions if this person is unsure how to fit. Once the display is out, the process is simple. They are AUD$60 each including shipping. Email at [email protected]
8/22/2019 1:02:19 AM • Janome Memory... • Answered on Aug 22, 2019
2answers
Janome 8000 LCD question
Try this link for an affordable solution to repairing your Janome MC 8000 Display Back.https://sew-bright.com/products/janome-memory-craft-8000-lcd-backlight-replacement-kit
8/22/2019 1:00:07 AM • Janome Memory... • Answered on Aug 22, 2019
3answers
Need touchscreen backlight for merory craft 8000
When your Memory Craft 8000 or MC 5700 is otherwise working fine but the LCD display screen begins to grow darker and you find you just can't read it, the only thing you can do is replace the LCD screen, or buy a new machine.
Janome no longer stock this item direct, but there is an affordable replacement available.
Full Access and Installation instructions are provided, so you can DIY or have someone else do the replacement for you.
Check this Link
Also includes advice, links & contacts to be able to Reset your screen and do a Self Diagnosis Routine to test your machine BEFORE you purchase a replacement LCD backlight for either the Janome MC 8000 or MC 5700, so you can check that there are no other troubles.
8/22/2019 12:49:39 AM • Janome Memory... • Answered on Aug 22, 2019
2answers
Changing light bulb on Memory Craft 8000
When your Memory Craft 8000 or MC 5700 is otherwise working fine but the LCD display screen begins to grow darker and you find you just can't read it, the only thing you can do is replace the LCD screen, or buy a new machine.Janome no longer stock this item direct, but there is an affordable replacement available.Full Access and Installation instructions are provided, so you can DIY or have someone else do the replacement for you.Check this LinkAlso includes advice, links & contacts to be able to Reset your screen and do a Self Diagnosis Routine to test your machine BEFORE you purchase a replacement LCD backlight for either the Janome MC 8000 or MC 5700, so you can check that there are no other troubles.
8/22/2019 12:28:57 AM • Janome Memory... • Answered on Aug 22, 2019
Janome 9000. Some of the stick selections on screen do not respond. Why
This is a touchscreen problem. If you would like more details on the problem please contact us on [email protected]
6/30/2019 10:53:31 AM • Janome Memory... • Answered on Jun 30, 2019
Every time I hit the start button to perform
the sensor must not be working. I thought the 9000 lowered feed dogs automatically when embroidery option is choosen anyway. There is a manual as well as on screen drop feed dogs method for this machine
5/14/2019 9:16:57 AM • Janome Memory... • Answered on May 14, 2019
3answers
WHERE IS THE FUSE FOR THE JANOME MEMORY CRAFT
Remove the top cover by taking the two large screws and the small one under the handle, LHS.
Remove the left side cover. The hidden screw is a 2.5mm allen accessed through the vent.
Lay the machine on its back and remove the four large phillips screws on the bottom and the small screw for the side, paying extreme caution with respect to the embroidery arm.
CAREFULLY move the bottom to the left and out of the way.
Inside the body of the machine you will see a black box held in place by three or torx/slotted screws. Remove the screws and, as you slowly pull the box out MAKE NOTE OF WHICH WIRES PLUG IN WHERE.
2/7/2019 8:15:47 AM • Janome Memory... • Answered on Feb 07, 2019
Where can I get a replacement touch screen for a Janome Memory Craft 9000
Call customer support!
8/15/2018 3:19:22 AM • Janome Memory... • Answered on Aug 15, 2018
3answers
JANOME MEMORYCRAFT 8000 STEPPING MOTOR
if you ever have this problem, it is because you have had something in the way of the embroidery arm at the back of the machine, so it has not been able to move freely; you'll get a terrible noise as the machine is unable to do what it wants, slips gears or something and then can't bring the arm to its home position. But fear not, i have found if you turn the machine off and gently push the arm back home to touch the machine as it is the start position, when you turn it on, it will work fine and no harm done. just make sure the arm can move freely before you start embroidery!
7/13/2018 10:32:30 AM • Janome Memory... • Answered on Jul 13, 2018
Janome Memory Craft 9000 Computerized Sewing Machine Logo
743 questions posted
Top Janome Sewing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Janome Sewing Machines
Most Popular Question
when move needle 4 0 or 4 5 needle now
  • Sewing Machines
