Follow link and look up your code/fault number
https://printcopy.info/?l=en&mod=erc&brand=HP&model=LaserJet%20Enterprise%20600%20M602
SOURCE: HP Color LaserJet 4500 Printer
Here is your problem. Hope that this helps you.
54.1 PRINTER ERROR
Description:
Indicates that an internal power failure has
occurred.
Action:
1. Turn the printer off, and then turn the printer
back on.
2. Replace the high-voltage power supply.
3. Check the fuser to ensure jams have not
occurred.
Caution When clearing jams, the
thermistor can be damaged
causing this error.
4. Make sure there is not a fluctuation in the
power supply to the printer. Check that the
electrical specifications (see Chapter 1) are
met.
5. Replace the low-voltage power supply.
SOURCE: MY HP LASERJET 3005 DISPLAY ERROR 49.2F9D
Its already discussed in one of the forums for Hp.
check :-
https://forums11.itrc.hp.com/service/forums/questionanswer.do?threadId=1158526
Thanks
SOURCE: Hp laserjet M2727nf scanner error 52
First, power the printer off, wait for about 30secs and power on. If problem persist replace the scanner.
SOURCE: hp color laserjet 2600n displays error 55.1 turn off then on
hello friend i have a printer HPColor Laserjet 2600n it displays Erroe 55.1 Turn OFF/ON. How do i over come this problem?thx
SOURCE: Error E8 HP Laserjet MP1136
See this... http://h30434.www3.hp.com/t5/Other-Printing-Questions/m1132-hp-printer-gives-me-e8-error-code-is-it-expensive-too/td-p/907661
