Hardware & Accessories Logo
B
Brian Burn Posted on Jan 19, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replacing a Honeywell T6060 thermostat with a DT90E. Wiring terminal 1 (live)to A and 3 (CH on) to B. However, in my original thermostat I have two other wires. Terminal 2 is neutral and 4 is CH off.
Is it ok to tape these two wires Regards Brian
Kevin Edgar
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 65 Answers
  • Posted on Mar 17, 2019
Kevin Edgar
Expert
Level 2:
New Friend:
Cheetah:
Answers
65
Questions
0
Helped
15059
Points
134
If the switch is working normally without these two wires then yes tape off safely
5 Related Answers
Jaime Hernandez
  • 2351 Answers
  • Posted on Apr 09, 2008
SOURCE: Proper Gaggenau EB294 Oven Terminal Block to Cable Harness wiring
If you have this user guide go to page # 40 for wiring instructions.
HANK MCNEIL
  • 252 Answers
  • Posted on May 16, 2009
SOURCE: need wiring for honeywell pro 3000 in trane xe1200
the pro 300 is a single stage thermostat and can not be wired to control 2 heat stages seperately
Anonymous
  • 16 Answers
  • Posted on Aug 17, 2009
SOURCE: cannot get central heating working,for honeywell ST6400 programme
with y plan 3 connections on programmer HW on HW off CH on HW on to cylinder stat then HW call to Orange on Mvalve to power boiler and pump HW off to grey wire on Mvalve to close hot water CH to room stat common then heating call to white on Mvalve
ja5767
  • 82 Answers
  • Posted on Sep 21, 2009
SOURCE: Wiring new RTH2310 DIY Honeywell
is the j2 jumper on the backside of the display set for hg instead of he - g is gas/oil e is electric - if correct take thermostat wires off screws and turn power back on - see if burner fires up with no thermostat wires connected - old wires could be touching somewhere when put on new thermostat
john224
John Prohaska
  • 1378 Answers
  • Posted on Apr 26, 2010
SOURCE: Low/High Switch wiring for Hayward Superpump
I do not read anywhere that you have a 230V DPDT switch which you will need in order to select the high or low speed. You will have 6 terminalas on the switch. Line connections usually go to the middle set. Put put sides of one pole to the common terminal and put one of the other posts to the hi and the other to the low terminal. I prefer to use am on-off-on switch so the switch in the middle turns off the pump. Flip it one way for hi and the other for low. If you post your stock number from the two-speed motor I could give you a more accurate diagram if you need it. Generally, 1 is common, 2 hi and 3/4 low.
Changing a honeywell T6060 room thermostat to a T6360B. The current wires are wired as 1 Red 2 has 2 Black and Live has another Red. Which of these wires should be connected where on the T6360B?
Can someone please tell me what a honeywall t6060 for and how to use it cause if it's for the aircon so its warm as well as cool then I'll like to knw as it dosentvwork past 15 and cuts out otherwise it's just cold and hot able thanks
1helpful
I would like to know how to wire honeywell dt90e thermostat which wires where i have 5 wires from wall
It helps to know which wires went to the terminals on the old thermostat, if it had one. Otherwise, you would really need to know how they are hooked up inside the furnace/air handler. Some technicians hook them up differently, but I can give you the basics and most commonly used wires. R terminal- red/power wire G terminal- green/ fan wire Y terminal- yellow/ cooling or condenser wire W terminal- white/ heating wire C terminal- blue/black/ common or ground wire If you have a rc/rh terminal, they are usually jumpered with a small wire and your power wire still hooks to that. Hope this helps and good luck!
4helpful
I need to replace an old Thermostat that just has 3 wires coloured Red, Blue and Yellow. The Honeywell THR830TUK Thermostat I have bought shows 5 wires on the diagram. I'm not sure which wire goes into...
The honeywell THR830TUK thermostat does not require a neutral as shown in the instructions.Connect the LIVE to terminal "1" and your YELLOW SIGNAL wire to terminal "3".
Connect your EARTH (if you have one) to the EARTH connection on the top left hand corner of the thermostat and blank off your NEUTRAL wire with a block connector.These instructions were supplied to me by Honeywell Customer Support.Hope this helps.
Replacing a drayton rts8 to a honeywell dt90e thermostat
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Honeywell Central Heating temperature control
R comonY cool W heat G fan C other side of 24 unless you are battery operated. On the back of the Tstat tou should have switch that says gas or electric this controls how the fan operates. If not go into programing and program 1 stage heat one stage cool.Let me know I will walk you thru this.
Cannot get central heating working,for honeywell ST6400 programme
Honeywell junction Box and QE2 Programmer
Hi check the wiring to the cylinder stat is there power to it then is it going to the valve
My heat is turning on but the fan isnt working. my honeywell thermostat is showing a flame and a blinking battery, and i know nothing about this thermostat, we just moved in . Can u help?
This is not a PC problem
Symptom
Heating comes on, but sometimes it
gets too hot, sometimes too cold.
Neutral not connected
Cure
Check wiring in room thermostat. Look for a
connection to the Neutral terminal (N 2 on
the Honeywell T6060, T6160, and T6360).
Make sure that it is connected (check
continuity).
If there is no neutral available, replace with a
two-wire thermostat, e.g., CT200, CM61 or
CM67. These will also offer extra energy
savings, (Without a neutral connection, the anticipator within the room thermostat does not work,
so the temperature control reduces from ± ½ºC to ±3ºC. People can feel a six degree
temperature swing. Then, if they try to adjust the room thermostat to overcome the
problem, the temperature swings become even worse.)
2helpful
Changing a room thermostat a potterton to honeywell t6360
I think I've done it - but don't take this as absolute truth.
For the Honeywell T6360B the original Potterton wiring should be rewired as follows:
Brown [Live] goes to terminal 1; Blue [neutral] goes to Terminal 2 and the yellow/green [which is not an earth but a switched live - i.e. gives live to the heating system when the thermostat clicks in] goes to terminal 3.
Obviously all done with the power isolated and when it was switched back on we had heating again :o)
It's been on over two hours now and all seems fine.
Top Honeywell Hardware & Accessories Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
David Spradling
David Spradling
Are you a Honeywell Hardware and Accessory Expert? Answer questions, earn points and help others
