c
clevert Posted on Oct 17, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I dont why my calculator Casio 9860gii has a problem in the graphics and it says error gama, can you help me.
It is in the part graph. MAIN MENU
k24674
Level 3:
  • Casio Master 8,093 Answers
  • Posted on Sep 22, 2018
k24674
Casio Master
Level 3:
Answers
8093
Questions
0
Helped
4675921
Points
21596
Graphical memory error, probably. You are using too many points (values ) of the x-variable. The step (increment) is too small.
5 Related Answers
k24674
  • 8093 Answers
  • Posted on Jul 25, 2010
SOURCE: Casio fx-9860G graphics calculater, vertical line segment
I am not sure how you can create such function (the range limitation do not work for x=c) but you can draw a vertical segment, just do not call it a function.
Draw a graph Y1=0
Then press SKETCH function key and use the F6 key to cycle through the TABS at the bottom of the screen. Look for the TAB named PEN. and click the function key below it.
Use the arrows to move the cursor to a spot on the screen (near the bottom), Press EXE to fix the starting point of the segment. Then use the Up arrow to draw a vertical segment from bottom to top.
Anonymous
  • 3278 Answers
  • Posted on Jul 06, 2009
SOURCE: I'm looking for a free user manual for my casio
Well, I found a manual for the fx-7400g calculator:
http://support.casio.com/manualfile.php?rgn=1&cid=004002007
Hope that helps.
Anonymous
  • Posted on Aug 05, 2009
SOURCE: Casio FR-2650PLUS Calculator Error Code
the ink roller installed wrong, remove ink roller, re-install it
k24674
  • 8093 Answers
  • Posted on Dec 03, 2009
SOURCE: Casio fx-7400G PLUS cubic solver?
First let us repair the terminology.
  1. You can evaluate any expression (find the value of any expression for a particular value of its variable).Store a value in the variable, say X. Key in the expression and press [EXE].
  2. You can consider your expression(should not contain a relational operator such as =, greater than, less than, greater than or equal to, less than or equal to) to be a function Y1(x) = expression and graph it, or generate a table for it. You will have several values of the function calculated at various points.
  3. You can set your expression equal to 0 and find the particular value(s) of the variable (the unknown) that make the equality TRUE. That is called solving an equation.
I am not sure that it has a solver (solving an equation or an inequation) but you can always draw your expression as a function and explore the graph (SKTCH) to locate the roots (or zeros) of the functions (the values of the variable where the function equals zero.) That is called solving graphically.
Hope it helps.
Thank you for using FixYa and for rating this solution.
k24674
  • 8093 Answers
SOURCE: CASIO Power graphic /fs 7400G PLUS - how do I
Turn a calculator ON. If you see no icons, press [MENU]. Use the arrows to move the focus on the icon MEM and press [EXE]. Agree to reset all memory. If you need further instructions download the manual from the Casio website.
Hope it helps.
Thank you for using FixYa and for rating (NOT BERATING) this solution.
What is an Ma error casio fx-9860gii
Ma error means Mathematical error.
Check input values and make corrections to ensure that values are within allowed limits.
Please Check the manual for the calculator. It is available on the Casio website. Here is the link.
fx 9860G fx 9860G SD Calculators Manuals CASIO
1helpful
Screen starts fade away
You can try to increase the contrast of the display.
Press Menu.
Press F:System
Press F1:Contrast.
Use the right arrow to increase contrast. If there is no change, the calculator may be damaged. But do a calculator reset just in case
MEMORY ERROR MESSAGE
Exactly what were you trying to do? It helps to understand the problem you are having. Usually it means that the result exceeds the capacity of the memory (Too big). The upper limit for the calculator is 9.9999999.. *10^(99) or 10^100.
Find the percent bottom on the casio fx9860gii
[OPTN][LIST] scroll right till you find %.
It is used inside programs and works on lists.
Create a list of data and type it in under STAT
Close the list editor (Press Menu to go to Run>Mat).
In Run>Mat Press OPTN>List>F6..>%.
The word Percent is displayed. Enter the name List (OPTN>List) then the list number (1-6). This is what you see (without the owrd Done).
Press the EXE
The calculator displays a list with the same dimension as List 1. Each element represent the % of the corresponding element of list 1 with respect to the total of the list L1.
In fact it calculates the relative frequency of each element.
Maybe that does not answer your question but really converting a decimal to a percent value or a percentage into a decimal is a rather trivail matter. Just move the decimal mark (if there is none put one at the end of the number) two places to the left to get the decimal equivalent or two places to the right to get the percent equivalent of a decimal number.
How to use square root for non square numbers for casio graphing calculator
You can use the square-root function for any number, whether it's a perfect square or not. For example, to calculate the square root of 2, press SHIFT [square-root] 2 EXE .
[square-root] is on the x^2 key, just to the right of the ALPHA key.
2answers
How do I get the answer into another square root. for example- Square root of 6 times square root of 15 is 3 times the square root of 10. But on the Casio FX9750GII it comes up as a decimal, how do i...
You cannot. The calculator does not have the Natural Display (math display) feature. I have heard that you can flash it with the OS of an FX-9860GII. At your own risk.
My fx-9860GII would not connect to my computer. why is it?
You may be using the wrong cord, or you may lack the proper software to use it. If this is the case then you can get it from the link below.
http://software.informer.com/getfree-casio-fx--9860gii-manager-plus/
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
