20 Most Recent
Casio FX-9860GII SD Power Graphic Calculator Questions & Answers
Screen starts fade away
You can try to increase the contrast of the display.
Press Menu.
Press F:System
Press F1:Contrast.
Use the right arrow to increase contrast. If there is no change, the calculator may be damaged.
But do a calculator reset just in case
Find the percent bottom on the casio fx9860gii
[OPTN][LIST] scroll right till you find %. It is used inside programs and works on lists.Create a list of data and type it in under STAT
Close the list editor (Press Menu to go to Run>Mat). In Run>Mat Press OPTN>List>F6..>%.The word Percent is displayed. Enter the name List (OPTN>List) then the list number (1-6). This is what you see (without the owrd Done).
Press the EXEThe calculator displays a list with the same dimension as List 1. Each element represent the % of the corresponding element of list 1 with respect to the total of the list L1.In fact it calculates the relative frequency of each element.
Maybe that does not answer your question but really converting a decimal to a percent value or a percentage into a decimal is a rather trivail matter. Just move the decimal mark (if there is none put one at the end of the number) two places to the left to get the decimal equivalent or two places to the right to get the percent equivalent of a decimal number.
How do i do prime numbers on the NEWYES NY-991MS calculator and CTIFREE fx-991ES PLUS calculator?
The NEWYES NY-991MS and CTIFREE fx-991ES PLUS calculators do not have a dedicated "FACT" button like the Casio FX-83GTX. However, you can still find prime numbers on these calculators.To find prime numbers:NEWYES NY-991MS:Press the "MODE" button.Choose "PRIME" from the list of options.Enter the desired number and press "=" to check if it's prime.CTIFREE fx-991ES PLUS:Press the "MODE" button.Select "TABLE" or "TABLESET."Input a starting point and an ending point, then observe the table for prime numbers.Although the techniques may vary from those used on the Casio FX-83GTX, they prove to be effective for prime number calculations on the designated calculators.
Casio QT-6600 kitchen printer stop working.
Is there lights on, on the printer? Does it have a receipt paper roll in it?
You can do a Power Cycle of the Terminal and the Printer. Unplug the printer for the wall socket. Remove the data socket, replace the data socket making sure the connection is tight.
Disconnect the terminal from the main power, and count to 20. Plug the terminal back in.
Now go to the kitchen and plug the printer back into the mains.
The reset should fix it. The rest is in the manual, which I told you earlier today. Yes it is complicated and you may have a network switch if you have multiple terminals and possibly a computer joining everything. If you find that too complicated, call the company that sold you the unit and tell them to bring a new ticket printer with them 'just in case'. That type if ticket printer is fairly specialized, but they are common. They normally don't charge for that type of help
In the manual under Remote Printer Control.
https://totalpos.co.nz/wp-content/uploads/2020/03/QT6600-Reference-Manual.pdf
More here
https://www.google.com/search?q=Casio+QT-6600+connect+kitchen+printer
How to calculate percentage with Casio fx-991EX?
To find the percentage of a number: Let's say you want to find 20% of 150.
- Enter the number you want to find the percentage of (150 in this example).
- Press the multiplication key (*).
- Enter the percentage value (20 in this example).
- Press the percentage key (%).
The calculator will display the result, which in this case is 30 (20% of 150 is 30
