Motorsports Logo
b
bobb Posted on Aug 06, 2017
2017 TaoTao 50 replace air filter
50cc motor new carb runs better without a filter you need a filter, don't you? Can you recommend a good air filter to go with a 2017 TaoTao 50 Thanks, Bob A
Workshopmanualsorg
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 05, 2022
Workshopmanualsorg
Contributor
Level 1:
Answers
Questions
0
Helped
1377
Points
Download Workshop Repair Manuals, Wiring Diagrams, EPC's for all cars, vans, trucks, lorries, etc. Petrol, gasoline, diesel, hybrid PDF & OEM from Workshopmanuals org.
kipngenoh winston
Level 1:
  • Posted on Apr 07, 2021
kipngenoh winston
Contributor
Level 1:
Answers
Questions
0
Helped
1377
Points
Hello. personally I will recommend 35mm AIR FILTER for Chinese made 50cc, 70cc, 90cc, 100cc, 110cc, 125cc Kids Taotao ATV, GO-KART, POCKET BIKE, DIRT BIKE
2 Related Answers
Anonymous
  • Posted on Nov 30, 2008
SOURCE: homelite hb 180 leaf blower
Changed all major gaskets: Cylinder to crankcase, case half, exhaust & carb. Now it runns right. The carb can be adjusted and the choke is full open when warmed up as it's supposed to be.
Gaskets ca be bought from Homelite directly at http://www.homelite.com/service_support/order_parts
Enter the model numbers & see the exploded views. Torque values are provided in the parts lists.
wrench002us
paul karo
  • 97 Answers
  • Posted on Sep 17, 2014
SOURCE: Need manual 2013 taotao 50 cc scooter
ebay
I just installed a high performance air filter for my taotao 50cc scooter and it starts and idles nicely but when I go to accelerate it bogs down and dies...why is this happening
The new filter allowing more air into the motor throwing off the air to fuel mix ratio you can either adjust the carb or put the factory filter on
1helpful
Toro lawn mower troubleshooting
Clean the carb, gas tank and fuel line (s). Replace air filter with a new one, I wouldn't recommend that you run it without the filter because that allows dirt and grass debri to enter the carb, fuel line and gas tank.
Replace the plug with a new one that is recommended for your engine.
Check oil level.
Other option is lawn mower repair shop....
Hope this helps, I had the same problem.
May 11, 2013 • Garden
50cc taotao scooter the carb is runs then fills with gas untill it stalls out dont get much off the searchs i have made dont no if it is the carb our choke broke down carb and looks clean no clogs or
My 2012 Taotao 49cc scooter was spitting and sputtering then just died one day. I brought to a small engine repair person and come to find out, the hoses that came off the carb had cracks in them. Changed the hoses and the problem went away. Hope this helps.. I have since replaced the cheap hoses with new ones from the auto parts store and never had the problem again.
My scooter would die on me all the time is is new.It acted like it had no fuel so i tuck carb off to inspect found nothing wrong. Looked up and seen filter was on backwards so turned around now wont start...
At this point, you are probably better off bringing it in under waranty because if its evident you messed with it, they might try to void your waranty. Thayt being said, have you tried running it with the gas cap removed? If the cap is bad it can create a partial vacuum in the tank and produce the symptoms you describe.
Top TaoTao Manufacturer Inc Motorsports Experts
ADMIN Andrew
ADMIN Andrew
Paula Hamilton
Are you a TaoTao Manufacturer Inc Motorsport Expert? Answer questions, earn points and help others
