Hello. Well, that's because Vizio offers no tech support even to service centers. I have never encountered a while screen on a Vizio, but my best guess is that the Main board is defective, although it's possible that it's a Timing Control (T Con) board. For part numbers, and possibly parts, go to ShopJimmy.com and enter the model number in the search bar. Hope this helps!
SOURCE: TV shows orange light but doesn't work
Have you tried taking it to Costco for an exchange? Other than their strict return policy on many electronic items, they are very good about customer service. They may make an exception if you take it in and talk with a manager in person.
SOURCE: vizio 46 hdtv screen has scratch now I can see a white speck
sorry to say you,ll need a new lcd screen
big bucks
SOURCE: vizio screen went white
Im sorry but did you figure this out yet. my tv just did this today too. it broke now.
SOURCE: Vizio 42 in TV LCD HDTV white line across to of
That white line (usually jagged) is actuallly part of the transmitted picture. However, you are not intended to see it because it is located in what is known as the 5% overscan area. Your TVs today are more than just cable ready... they are a versital, technology filled multimedia display. You can see that line because the screen size or wide mode you are using is intended for 1080p/24 signals. You have 0% overscan with this screen size setting. This allows you to see ALL of the picture, including portions of the picture the broadcaster did not intend for you to see. You can change your screen size using the Wide feature in the Setup menu. See pg.62 of your user manual for details and descriptions of the various wide modes.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
