Viva Wine Cellar Self Cleaning Water Cooler 8HWCDCHK-SC-B Logo
r
roger Posted on Jul 28, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water cooler spout is leaking
Constantly drips from cold water spout
dheerajkaila
Level 2:
Spread the Word:
An expert who has shared 5 answers on their Facebook wall.
New Friend:
  • Expert 97 Answers
  • Posted on Mar 11, 2019
dheerajkaila
Expert
Level 2:
Spread the Word:
New Friend:
Answers
97
Questions
0
Helped
12931
Points
293
APPLY MELTED PLASTIC OR GLUE GUN TO FIX
Cold water spout started dripping in the middle of the night.
no info generic answer valve or seal needs adjustment or replacement
How to stop slow drip from cold water on Vitapur. Water cooler ?
turn the main stop **** off then repair and re seal were the leak is
12helpful
3answers
I am unable to use the Bellagio water cooler now as the cold water dispenser is leaking. There is a constant drip so I had to remove the water bottle, then drain all the water from the reservoir. I have...
Go to www.super-electric.com and send them a message about your problem. They have parts. I can't tell you if they will help you or not, I have just emailed them today as well. I have both sides of my 1 year old water cooler leaking, model W074DRF11BQD. (from Zellers) I have hardwood floors and I would rather throw this unit away than risk water damage. If anyone is reading this and thinking of purchasing one of these Bellagio water coolers, spend your money elsewhere - THEY LEAK!. My husband is very handy and has just spent 2 hours on it with NO success. The parts are defective - this unit is NOT full of complex working parts. One plastic part causes pressure on the valve and causes a leak(s). After light usage and nothing damaging it, 8 months old one side went and the other side has been leaking for a couple of days and we are just coming up to a year. If anyone else had this problem and fixed it, I would love to hear the solution.
1helpful
When i turn the spout water is dripping out from
There are "o" rings between the spout and the body of the faucet that are getting worn and causing the leak. You need to replace the "o" rings. Shut off the water supply (both hot and cold), remove the handle, and then the spout should slide off exposing the "o" rings. You can get replacements at the hardware store. Put some vaseline on the "o" rings when you reassemble the faucet to keep the "o" rings from curling up and moving out of place. Good Luck.
Oct 22, 2009 • Plumbing
Frezzer leaks into fridge
This is usual. In some refrigerators it is designed that way. It will keep the vegetables etc. in the fridge from drying out. Usually this spout is close to the back wall of the fridge. It is designed such that water drips directly to a small hall on the bottom of the fridge. It is important that you don't push the dishes or food in the fridge too far back. Otherwise water will be on you food. This spout should be far back as I mentioned. If, for some reason the water is dripping not close to the back, the spout may have beent damaged or bent. Check to see whether it is OK.
1helpful
Dripping shower head
If it is dripping from the connection where it goes to the water spout you can unscrew the connection and wrap teflon tape or Pipe Joint Compound on the Threads. Now you can Thread the Shower Head Back on, with No Leak. IF..... It is leaking from the Shower Head Itself There May Be a Problem with the diverter handle/lever. If it has a Pull Type Lever, sometimes you can screw the Lever up or down for the proper water restriction to the Shower Head. However if the Hot and Cold Handle/Lever is OFF, There should not be any Water coming out from anywhere! If water is coming out off the Tub Spout, with the Shower Off, then you will have to replace some washers or Cartridges in the faucet(s) to stop the dripping. You can do this easily....Just Ask) Remember though, that some shower Heads may Drip for a Few Minutes After they are Turned off. There is still water in the Supply neck and needs to escape, either though the tub Spout or Shower Head.......Hope this Solution Helps you with your Drips.....Joe
5helpful
2answers
Oasis water cooler taps started dripping
if the cooler is a hot and cold, even if its a cook and cold, the cooler always needs to be cleaned and maintained, not only on the inside but on the outside, as the cooler is used calcium builds up over time. that is why your taps are leaking, there is a build up in the taps, therefor the taps are not sealing properly and letting some water thru. i say take the taps out and clean them with vinegar.
the second thing u can do is the taps do come apart into smaller peices once u disconnect them from the cooler. take the taps apart and find the spring located within it, stretch the spring and than reconnect the peices together than reconnect to the water cooler.
Nov 14, 2008 • Oasis P1AQ
Problems with Black & Decker #900144 TopLoad Water Dispenser: It is dripping water constantly and the item is only 4 mnths old
you have to open it up and look where the water is dripping from. it could be from the rubber hoses that connects the tank to the faucets.
if it's on the hoses, that would be easy to replace, but sometimes the leak would come from the stainless tank whiich would be very hard to replace.
tnx 4 using fixya,
drcool
6helpful
Top Viva Furniture Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Viva Furniture Expert? Answer questions, earn points and help others
